way to fix plug ins on wiring harness
Old Aug 3, 2013 | 02:48 PM
BigHoss_27's Avatar
Some clips are broke and don't know wht to do
Old Aug 3, 2013 | 03:28 PM
rustypigeon's Avatar
Many of the connectors are still available from the dealer. The connectors have a 5 digit number on them. The connector part numbers are 90980-xxxxx, with the last 5 digits being the number on the connector.
For example, if you look closely at the coolant temperature sender connector, you will see the number 10737. You can order this as part number 90980-10737.
Old Aug 3, 2013 | 03:42 PM
BigHoss_27's Avatar
How would you change them out?
Old Aug 3, 2013 | 04:30 PM
rworegon's Avatar
This may help.
Search for google for Toyota Wire Harness Repair manual.
Old Aug 3, 2013 | 04:48 PM
BigHoss_27's Avatar
From what I read if the plastic piece is only broke you just find lock and pop it and pull off and replace with new
Old Aug 3, 2013 | 09:01 PM
wyoming9's Avatar
Red face
If your replacing the plastic connectors you need to remove the pins be they male or female and install them in the new plastic connector.
unless your doing something different
these connectors get brittle from thermal cycling on these older trucks quite a few of mine are held together with black tape
Since a new harness can no longer be bought for my 87 4Runner
Old Aug 3, 2013 | 09:08 PM
BigHoss_27's Avatar
I bought a used harness and like 4 plugs are cracked or broke and can I put the good ones from old harness on it?
Old Aug 4, 2013 | 12:07 PM
wyoming9's Avatar
Red face
Yes you can but you need to know how.
If you have a copy of the FSM it tells you how to remove and insert the pins.
Old Aug 4, 2013 | 12:39 PM
BigHoss_27's Avatar
Where con I find one of these
Old Aug 4, 2013 | 02:17 PM
BigHoss_27's Avatar
Where can I find FSM should I say
Old Aug 4, 2013 | 02:22 PM
Go to this link...
http://www.autoshop101.com/
then click on "technical articles"
then under "Toyota series- Electrical" find the pdf called "05 Wire, Terminal and connector repair".
That will tell you how to replace wire connectors.
Old Aug 4, 2013 | 06:49 PM
BigHoss_27's Avatar
Here is what I need to get off
Attached Thumbnails way to fix plug ins on wiring harness-forumrunner_20130804_224752.png   way to fix plug ins on wiring harness-forumrunner_20130804_224804.png   way to fix plug ins on wiring harness-forumrunner_20130804_224817.png   way to fix plug ins on wiring harness-forumrunner_20130804_224831.png
Old Aug 4, 2013 | 07:05 PM
BigHoss_27's Avatar
And I don't see how to do it
MO transplant
Apr 23, 2023 11:58 AM
icentropy
Sep 16, 2020 02:47 PM
steve miller
Oct 10, 2015 01:40 AM
msane99
Jul 17, 2015 10:13 AM
smiley52
Jul 11, 2015 05:16 AM
