Wasn't someone making/selling knock sensor pig tails.
Old Feb 13, 2011 | 07:46 AM
mitfan311's Avatar
Thumbs down Wasn't someone making/selling knock sensor pig tails.
I don't really understand the concept of the knock sensor having a shielded system. I do a little but I just don't care anymore. Wasn't there someone who was making replacements. I've got a new knock sensor and the short wire from sensor to harness is crispy and crunchy. I hate code 52. Does anyone have a good one for sale or how much does it cost at the dealer. I'm tired I just want it to stop throwing the code. Can anyone help? Using my iPhone makes it harder to find this part. But it's all I have. What can I do while I have it exposed. The dealer isn't open today.
Please help
Wesley
Old Feb 13, 2011 | 09:10 AM
shaeff's Avatar
Wesley, read over the Code 52 Tech thread which is linked in my signature.
To clarify for you, code 52 is really a simple problem. It's what happens when the ECU does NOT receive a signal from the knock sensor. It's just an electrical problem, which narrows it to:
- knock sensor wiring
- Kncok sensor
- ECU (not usually the problem)
Old Feb 14, 2011 | 07:13 AM
scope103's Avatar
Part 219-35010 $11.31 at http://www.toyotapartszone.com
So if your dealer really wants to rip you off, it might set you back a sawbuck.
Just get it from the dealer.
Old Feb 14, 2011 | 01:04 PM
FleshThorn's Avatar
I am pretty sure that the pig tail wire itself is not shielded, but the rest of the wire is. A regular female spade connector will work, but I have no idea how the heat from a V6 is going to effect it after a while. When I was in the process of fixing my Code 52, an unshielded jumper wire running out the fender well and through the passenger door to the ECU would work, but when I tried to route it through the firewall I would get a Code 52. I ended up using a piece of coax and the KS connector from the above mentioned pig tail.
Old Feb 14, 2011 | 01:29 PM
Ricky B's Avatar
I just ordered the 82219-89103 from Toyota of Carson for eleven bucks and change. Gonna tackle this project tomorrow along with the intake mani gaskets and the PCV valve.
Good times......
Old Feb 14, 2011 | 01:47 PM
shaeff's Avatar
Don't use a spade connector. The OEM connectors are very well sealed and make a secure connection that won't corrode. A spade connector is a hack job.
Old Feb 14, 2011 | 01:50 PM
Ricky B's Avatar
So you're calling a spade a spade?......
Old Feb 15, 2011 | 10:09 AM
shaeff's Avatar
Old Mar 24, 2011 | 09:11 PM
Gordon12's Avatar
So did it ever fix the problem?
raptor510
Aug 19, 2015 02:15 PM
rjtrials
Aug 6, 2015 07:25 PM
Flossy
Aug 5, 2015 05:14 PM
nonstop
Jul 24, 2015 06:29 PM
