warm rattle rattle rattle *please help*
Old Mar 23, 2008 | 11:10 AM
toytech76's Avatar
actually, if you have the tools and know how, you can chage out the drivers side guide without pulling the head. I have tools to reach down with the v/c off and replace it. Saves alot of time and unneeded trouble
Old Mar 23, 2008 | 01:35 PM
Matt16's Avatar
I take the valve cover often. It takes ten minutes and there are two vacuum lines to disconnect that go to the power steering pump. You can unbolt the metal flap on top of the valve cover and flip it out of the way still connected.
The only things to watch are the two half-moon shaped pieces of rubber at the back and front of the head. RTV seal them back in place, especially at the corners.
Matt
I'll PM you my cell number and if you want I'll talk you through it.
Old Mar 23, 2008 | 02:05 PM
toyotatom93's Avatar
Hey thanks Matt, it's snowing right now so I wont be doing it today it looks like...If I run into any problems I will take you up on the offer.
Old Mar 23, 2008 | 07:45 PM
Managed to get some video, hopefully it may help
Before the rattle, what I consider normal sounds
http://www.youtube.com/watch?v=J0J9yUQR9UQ
This is what it sounds like with the rattle
http://www.youtube.com/watch?v=QdQZa55xHYg
Old Mar 23, 2008 | 07:55 PM
  #25
abecedarian's Avatar
Heat shield over the exhaust manifold?
Old Mar 24, 2008 | 05:18 AM
  #26
Hey thats what some other people thought, and it did sound like the headers were making the sound. Thanks, I will check it as soon as the sun comes out here.
Old Mar 24, 2008 | 07:23 AM
  #27
AH64ID's Avatar
I know your in canada, but your engine is backwards... could cause some serious rattles
Not too sure.... Thats a much faster rattle than I had with the TO bearing....
Old Mar 24, 2008 | 08:17 AM
  #28
ovrrdrive's Avatar
It's ticking to fast to be a manifold leak unless it's multiple cylinders. It could be at the collector, but honestly I think that would get quieter as the engine warmed not louder.
It sounds like valve train or timing chain rattle to me. I'd have to hear it in person to make a better guess. If it is valve trail noise due to wear it will actually get louder when you adjust the valves to proper spec. See if you can get a stethoscope and narrow it down a little.
Old Mar 24, 2008 | 07:19 PM
  #29
http://www.youtube.com/watch?v=m-dz6cQ8yn4
There is another vid at night so you cant see anything but I am reving it this time.
I also took off the valve cover and the guides looked fine. I also took off the header cover and from what I can see it looks fine. I am pretty green myself but from what I saw evrything looks normal to me.
Old Mar 25, 2008 | 02:40 PM
  #30
anthonyallred's Avatar
IS it more lick a ticking than a rattle???
Old Mar 25, 2008 | 02:41 PM
  #31
I have had the same issue an it hasnt happened for a while. it did seem to happen when the vehicle warmed up?? but it happens at different times not always at the same point.??? this sounds like a bad bad problem?? should i avoid long trips?
ashamsuddin
17
Jul 22, 2024 03:59 AM
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
gentry
Sep 28, 2015 06:16 AM
