Very High pitched whine
Old Dec 15, 2008 | 02:38 PM
86autoyota's Avatar
It's a very high pitched kinda whine/ring and it only happens when going between 40-55ish and when im on the gas. As soon as i let off it goes away.
any ideas?
Ive got a 86 pickup 22re
Old Dec 15, 2008 | 03:25 PM
86autoyota's Avatar
bump-
Old Dec 15, 2008 | 03:30 PM
AZ89LONGBED's Avatar
Rear pinion???
I had a similar problem in a CJ-5, it ended up being the rear differential was over-filled with fluid after servicing.
Old Dec 15, 2008 | 03:35 PM
86autoyota's Avatar
that makes sense because i recently regeared and installed a locker, so you think that over-filling the diff would cause that noise?
Old Dec 15, 2008 | 04:01 PM
Aye, that's what i'm sayin'... My noise showed up between 46-49 MPH, under acceleration only, similar to your problem...
Old Dec 15, 2008 | 04:03 PM
86autoyota's Avatar
hmm interesting well thanks for some input!
Old Dec 17, 2008 | 08:58 PM
Any luck??
Old Dec 17, 2008 | 10:41 PM
Matt16's Avatar
How would you over fill the diff without it coming right back out the fill hole. You'd really need to stand the truck on end to over fill a diff, and if your truck is standing on end, you have bigger fish to fry than properly filling the diff
Old Dec 17, 2008 | 10:43 PM
Matt16's Avatar
Where is this wine coming from, front or back. It is possible the backlash wasn't reset properly.
Old Dec 18, 2008 | 08:28 AM
thook's Avatar
Matt16 has a very, very good point. Can't really overfill the diff....hehe.
Old Dec 18, 2008 | 09:26 AM
TNRabbit's Avatar
I believe what you're hearing is my ex-wife in Tennessee....
Old Dec 18, 2008 | 09:37 AM
swaycleveland's Avatar
i would say seeing as how you had a gear change you has something out of wack in there i would ask ZUK to help
Old Jan 1, 2009 | 06:42 PM
Dude, my cj-5 (super-short wheelbase) had around 5-6 inches of lift, and the rear axle was setup spring over axle. I think I had around a 15-20 degree shim to realign my driveline angles, and it made it harder to fill the diff "full" because the drain plug was effectively lower.
Anyways, it invariably got over-filled by trying to squeeze more fluid in for fear of underfilling it. Then it made noise, and we took the diff cover off and rechecked everything, then refilled it with the exact amount specified, and it didn't make noise...
Anyways, what ever happened with your rear-diff noise 86auto?
Old Jan 1, 2009 | 07:04 PM
space-junk's Avatar
welcome to my hell...
sounds like the same problem that i have... in talking with ZUK, sounds like my pinion bearing is shot...
prolly your problem too... im going to try to tighten up the pinion bearing pre load, and while its out, reset the carrier bearing preload as well...
hope that you got it fixed okay...
justdifferentials
14
Jun 11, 2017 08:36 PM
Ktm526
Oct 7, 2015 05:14 AM
Daenerysdad
Oct 1, 2015 07:33 PM
potatopants
Sep 15, 2015 06:26 AM
Boomer8404
Sep 10, 2015 09:01 AM
