Vacuum help
Old Mar 29, 2023 | 01:20 PM
94basscatcher's Avatar
Vacuum help
Can someone please tell me where this vacuum line runs to. I have been all over the internet and cannot find a diagram showing where this goes. 3.0 V6
Old Mar 29, 2023 | 04:32 PM
nv4runner's Avatar
Seems to me that one is capped off on my 92 4runner. I'll vial when I get home tonight.
Old Mar 29, 2023 | 05:39 PM
nv4runner's Avatar
It should be fine if you cap it, though i have a manual transmission. An automatic might need a vacuum line.
Old Mar 30, 2023 | 05:51 AM
scope103's Avatar
The nipple you circled provides vacuum to the evap cannister through the TVV (Thermal Vacuum Valve, or Bi-Metallic Switching valve). The line on the left side of your photo is almost certainly that line. The nipple you have that line connected to is blocked from the factory. So you need to move the left vacuum line to the nipple you circled, and block the nipple it came from.
If you look at nvrunner's photo, his is set up that way.
PS: Your hoses are pretty degraded. I'm happy to keep mine with the fancy factory marking, but you can replace yours with off-the-shelf vacuum tubing. You don't need fancy silicone hose unless style points are important to you.
Wouldjaball
Dec 7, 2021 05:05 AM
greyheadedguy
Sep 9, 2019 02:42 PM
Pete1122
Jun 13, 2015 03:09 PM
aaron_crane
Apr 16, 2008 08:45 AM
Victor
Oct 20, 2003 08:20 PM
