Umm... What's this?
Whiskey Tango Foxtrot over.
Alright, I'm still getting used to owning a Toyota and dealing with SMOG, but I'm going to show my ignorance here.
What is this, and should those lines be cut?
~Thanks
~Thanks
watzzit?
If I'm not mistaken,..thats the distributor connector. I think the tubes are where you can push test lead ends down in there to check the signal from the distributor.
Could be way off though.
its a Kuhneutson Valve
you can get replacements from http://kalecoauto.com/index.php?main...&products_id=9
sorry i really have no idea
Edit:
You can see it in this photo, just slightly lower down, and it's connected to the dist.
http://www.bigflea.com/corolla/image...hernandez3.jpg
Btw, that wire on my truck goes to the distributor but I couldn't tell you what it's for and that one doesn't look the same as the one on my truck... I'll try to dig up a pic.
mpbowyer
Jan 10, 2012 06:07 AM
