Two vacuum line problems.3.0 95 4x4 pickup
Old Jul 1, 2012 | 05:26 PM
Roofmaster's Avatar
Just finished the reassembly of head gasket replacement.I only lost one socket and broke one part,which brings me to my vacuum question.Under the phlenum,bolted to the rear of intake manifold right in front of the firewall,is a sensor with a blue(in my case) plastic top and two vacuum outlets.I think I know where the bottom one goes(to the charcoal canister?) but I dont know where the top one goes.And I broke the plastic top off that bolt and super glued it together rather nicely I think,then coated it with black silly cone gasket maker,but still want to replace it when I get the truck going,so I can get to the parts store.So I also need to know what the part is called.Thanx.
Old Jul 1, 2012 | 05:33 PM
ksti's Avatar
I believe its your cold start time switch without seeing a pic
Old Jul 1, 2012 | 05:45 PM
Roofmaster's Avatar
I dont think its the cold start time switch.
Isnt the cold start time switch actually bolted to the passengers side of the phlenum,and wouldnt switch imply it had an electrical connector which it doesnt,it has two vacuum outlets and no wires or electrical connectors.
Old Jul 1, 2012 | 05:58 PM
ksti's Avatar
Sorry got a little ahead of myself here is a pic where it goes, just to the left of TPS on top of throttle body if your looking form drivers side. hope this helps
Old Jul 1, 2012 | 08:54 PM
scope103's Avatar
Thermal Vacuum Valve
https://www.yotatech.com/forums/f116.../#post51931128
ksti's photo shows the correct connection to the throttle body
Old Jul 1, 2012 | 09:05 PM
Roofmaster's Avatar
sorry bro still not the right part
The part I'm talking about can't actually be seen unless you take off the phlenum
The big top thing that says toyota 3.0 has to come off first then you can see it bolted to the intake right in front of the firewall.I will figure out how to get a pic on here tomorrow.Thanx again.
Old Jul 1, 2012 | 09:31 PM
scope103's Avatar
Only one of the sensors in the water by-pass outlet has vacuum to it. The others (temp switch, CSI timer, temp sensor) are electrical.
Old Jul 2, 2012 | 09:24 AM
Roofmaster's Avatar
OMFG I love this #@%&ing site.
Thanx guys you were right,going out to plug in vacuum lines put plugs and wires,oil and coolant in then turn the key,let you know how it turns out.
bigjstang
Jun 2, 2025 03:56 PM
zd92655
Mar 6, 2022 12:58 PM
Regency
20
Jan 3, 2020 07:43 PM
JF9243176
Oct 8, 2017 04:21 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
