Turn signals in trail gear bumper?
Old May 25, 2013 | 11:55 PM
RSR's Avatar
RSR
And your local auto parts store *should* have a selection of led flashers in stock. But you can also order online. Easiest would be to go to the out parts store. Yank your current one, and then ask them to find one with the exact same terminal wiring... This link should be the correct one to do, but I haven't done mine yet: http://www.superbrightleds.com/morei...asher/782/836/
Going to be ordering front hilux corner lights (have separate turn signal and parking light reflectors/internals) and piggy backing on front turn signals' wiring so only swapping to LEDs so I'm sure no wiring is getting overloaded... Also doing a relay for corners to alternate, but that's not germane to this convo.
Also, the advantage of stock flasher is that when you have a light burnt out it blinks faster to alert you that there's a problem with turn signals (believe greater than 130 blinks per minute -- it's in the FSM). The new one you're installing won't similarly indicate with blink rate, so you'll need to check your turn signal lights monthly.
Old May 26, 2013 | 10:03 PM
wyoming9's Avatar
Red face
I can see where it can get real confusing.
So many terms used interchangeably that can mean so many different things.
You have turn signals you have Hazard lights most often called anything thing from flashers fourways to 4 way flashers.
If your only changing the front turn signal lights.
You will need to change the flasher in the fuse panel on the left side in the cab remove the old one install the new one for the led lights
Old May 27, 2013 | 05:48 AM
Edionne13's Avatar
Left side of steering column?
Old May 27, 2013 | 06:40 AM
wyoming9's Avatar
Red face
Not real sure just what year your working on
But most the fuse panel is on the left side in front of the Door post
Behind the plastic trim.
If you don`t want LED lights you can get non led lights in the same shape and size.
Brackets to bolt or weld rubber grommets your good to go.
Old May 27, 2013 | 06:47 AM
  #25
Edionne13's Avatar
93 and yeah I'll keep LEDs
Old May 27, 2013 | 08:42 PM
  #26
RSR's Avatar
RSR
a51young & Edionne13 -- you should also be able to swap in hilux corner lights with their own independent reflectors/lenses and already present holes:
Buy them here for $64 including shipping (haven't done but on my future mods list): http://www.ebay.com/itm/88-97-Toyota...-/160911721856
Old May 27, 2013 | 08:49 PM
  #27
Edionne13's Avatar
What. Why can't we have hiluxs here! Diesel four door and come straight axled? Great job America Thames for the link ill keep that in mind I think I'm going to do the flasher and just buy new $7.00 lights from trail gear.
Old May 28, 2013 | 11:59 PM
  #28
RSR's Avatar
RSR
Cool beans.
I drive in the city more than offroad... So I figure if it helps to keep some yahoo from running into me, it's worth the small cost for prevention to add the extra turn signal light. When I update, I'm planning on doing a write up -- sometime before years end.
Old Jun 4, 2013 | 07:44 AM
  #29
SLAYfriknBODIES's Avatar
I don't mean to thread hijack here, but I have a relevant issue.
I wired in my Trail Gear LED turn signals and yeah, theyre flashing like a bulb is out.
Since I love the look of the TG signals, I'm looking to take the resistor route.
Does anyone know which size resistor I need to make the signals flash near stock?
Old Jun 4, 2013 | 07:47 AM
  #30
a51young's Avatar
if you have an ohm meter, measure the resistance across your original bulb and subtract the resistance across the led and thats the size your looking for.
Old Jun 4, 2013 | 08:02 AM
  #31
smracing's Avatar
Much better to modify the flasher or get an electronic flasher. The resistors have to be pretty stout to handle the current. They are bulky. Not to mention another wiring connection waiting to fail.
Old Jun 4, 2013 | 08:04 AM
  #32
I sort of cut the old ones off right after the bulb, to leave enough wire to reach the TG signals...
Old Jun 4, 2013 | 12:42 PM
  #33
Edionne13's Avatar
The flasher that is linked here earlier is what your talking about...?
Old Jun 12, 2013 | 09:05 PM
  #34
Edionne13's Avatar
Bought the flasher pain in the ass to get to the old one but anyways pulled it got it to not fit had to trim some plastic and fit snug. Tried to turn on hazards got nothin plugged in old one and then they worked. I'm at a loss here with the of blinking my then signasl
Old Jun 13, 2013 | 12:07 AM
  #35
wyoming9's Avatar
Red face
Just wish flasher did you get??
Mine was just plug and play no trimming of anything.
I used the Napa one.
It is possible you got one boxed wrong.
Old Jun 13, 2013 | 05:18 AM
  #36
Edionne13's Avatar
O.O really no one told me napa had one. Bought the one that was linked before. The one you bought for led turn signals?
Old Jun 13, 2013 | 07:15 AM
  #37
Scirocco16v's Avatar
If it helps, I have front turnsignal LED`S, useing 3 Ohm chasis mounted aluminum housed resistors, driving 8 LEDS ea.
Old Jun 13, 2013 | 03:34 PM
  #38
Edionne13's Avatar
Come to conclusion in need of resistor where to buy? The flasher doesn't work so I'm going different route
Old Jun 14, 2013 | 09:28 AM
  #39
I picked mine up off EBAY, but local would be RadioShack or the like.
Old Jun 14, 2013 | 01:18 PM
  #40
Edionne13's Avatar
Would you be willing to give me the link?
