tundra brake upgrade on a 94 4runner
Old Jul 13, 2016 | 02:15 PM
BUDD's Avatar
i always wanted to upgrade the brakes on it, the opportunity came to get a set of disc of a tundra and calipers, never seen it done on a 1994 4runner, so,
well, this is what i did,
first removed the whole assembly out to start checking how to fit it, and see what the differences in sizes
few pics for comparing (ish) the size of calipers, and disc.
calipers bolt pattern dont match
the disc its touching too much the dust shield,so need to trim it (about 10mm around) and i will shave behind the hub, to leave it level to the back of the wheel studs
Old Jul 13, 2016 | 02:16 PM
BUDD's Avatar
drilled holes to fit it like the factory discs
brackets made
and fitted
sorry, not the best pic
Old Jul 13, 2016 | 02:19 PM
BUDD's Avatar
then, the end, on 16s, nissan patrol wheels, not sure if 15s will fit, still some space around the caliper and wheel
now, wait till i got the paint job finish to fit it all with some 305/70r16 tyres
Old Jul 13, 2016 | 02:20 PM
BUDD's Avatar
i will fit 30mm spacers, to avoid the tyres rub
Old Jul 13, 2016 | 10:43 PM
wyoming9's Avatar
Just what difference in pounds per square inch with the brake upgrade compared to stock ??
In the applied braking pressure ??
overall increase is pad area ??
Old Jul 13, 2016 | 11:07 PM
BUDD's Avatar
im sorry about my ignorance, but i dont know how many pounds difference,
all i know its by being bigger disc/calipers= bigger pad area,
im lucky that someone put already 1inch bore master cylinder,
so definitely it will be an improvement on my old rubbish braking power.
Old Jul 13, 2016 | 11:29 PM
wyoming9's Avatar
Interesting how new brake parts work better then old worn out brake parts!!
I got the same improvement just by putting all new stock parts on funny how that works.
Old Jul 13, 2016 | 11:54 PM
BUDD's Avatar
very funny, of course i tried first putting new disc,pads,refurbished calipers flushed system with new fluid, and still not happy with it
if you say that because you think its for the one in the pic,you wrong, that's the one im using to check if all fits,
the one its going for, cant be stopped for too long due it still on service
Old Jul 14, 2016 | 11:12 AM
SacRunner's Avatar
Do you have a better picture of the bracket mounted, with and without the caliper?
While looking at various other brake upgrade threads (or maybe it was the widening a SFA with IFS parts thread) there was some discussion of people not trusting an add-on bracket for the caliper mounts (I'm not sure that I completely understand their concern) but are you worried about that bracket failing?
I like the idea though.
Old Jul 14, 2016 | 12:08 PM
wyoming9's Avatar
I was not going from your project at all .
The bottom line as long as your happy that is all that matters
Besides if I wanted to make fun of you I could do much better with my 5th grade education !!
Old Jul 14, 2016 | 10:37 PM
BUDD's Avatar
all good,
Old Jul 14, 2016 | 10:42 PM
BUDD's Avatar
im open to new/better ideas,
i asked several engineers, some said to weld it in position, some told me to leave it like this, yes, i will take some more pics, thanks.
Old Jul 15, 2016 | 11:40 AM
BUDD's Avatar
here they are, more pics.
1985 4Runner
Mar 2, 2016 10:24 AM
punks_is_4x4
Feb 23, 2016 11:52 AM
vikecowboy
Feb 9, 2016 07:31 AM
