tundra brake swap on SAS
Old Aug 18, 2012 | 06:49 PM
toyotanick's Avatar
hey guys, i have done the trail-gear ifs eliminator kit and have recently been looking around on the tacoma forum and read that the tacoma's are doing the tundra break swap. my question is, if i were to buy the tacoma caliper brackets for the toyota 8" front axle from front range offroad i should be able to do the tundra swap correct?
also, how will the brake master cylinder handle the bigger calipers? since this is a tacoma upgrade how are the 2 master cylinders comparable?
Old Aug 18, 2012 | 07:36 PM
ThatGuy1295's Avatar
I dont see why not.
Usually bigger calipers makes more braking power even with the same size master. Just increasing the size of the slave hydraulic gives more hydraulic leverage. So I think it would be to the same affect as the tacoma tundra brake swap. Way better brakes. IMO
But lets see what others have to say.
Old Aug 18, 2012 | 07:51 PM
toyotanick's Avatar
thanks for the insight that guy. i think trail gear and marlin and i am sure several other comapnies have a 1" bore master cylinder with a 2lb residual built into the master cylinder. other than the residual, should there be a difference in the master cylinder? will it have upgraded flow or pressure capabilities?
Old Aug 18, 2012 | 08:02 PM
On that im not sure. But I wouldnt think theres much a difference. Im sure somone who has delt with that will chime in here soon.
Old Aug 19, 2012 | 04:38 PM
toyotanick's Avatar
does anyone of you brilliant individuals know?!
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
crazypaint
Aug 13, 2015 04:32 PM
mengquis
Jul 13, 2015 10:39 AM
Suprarossa
Jul 6, 2015 05:21 AM
