tundra brake swap on SAS
hey guys, i have done the trail-gear ifs eliminator kit and have recently been looking around on the tacoma forum and read that the tacoma's are doing the tundra break swap. my question is, if i were to buy the tacoma caliper brackets for the toyota 8" front axle from front range offroad i should be able to do the tundra swap correct?
also, how will the brake master cylinder handle the bigger calipers? since this is a tacoma upgrade how are the 2 master cylinders comparable? |
I dont see why not.
how will the brake master cylinder handle the bigger calipers? since this is a tacoma upgrade how are the 2 master cylinders comparable? But lets see what others have to say. |
thanks for the insight that guy. i think trail gear and marlin and i am sure several other comapnies have a 1" bore master cylinder with a 2lb residual built into the master cylinder. other than the residual, should there be a difference in the master cylinder? will it have upgraded flow or pressure capabilities?
other than the residual, should there be a difference in the master cylinder? will it have upgraded flow or pressure capabilities? |
does anyone of you brilliant individuals know?!
