Truck won't start
Old Sep 23, 2009 | 08:48 AM
91Toyota's Avatar
Truck won't start
I've had this reoccurring problem for a couple months now...and it finally won't start.
Here is what it does...turn the key and click. Turn the key again and click. Might do this several times then it will start. Now all it does is click.
I've cleaned the battery connections millions of times now. I've banged on the starter. I've replaced the ground wire from the battery to the block.
The battery has 12.6v so I know its good.
The only thing I can think it could be is a faulty ignition?
Does that sound right? Any input is greatly appreciated.
Thanks!
Old Sep 23, 2009 | 09:01 AM
91Toyota's Avatar
Okay...it just started. I had to keep my foot to the floor to start it...then keep my foot on the gas to keep it idling until it smoothed out and a bunch of smoke shot out the exhaust. lol. Whatever Toyota.
Old Sep 23, 2009 | 09:06 AM
4Crawler's Avatar
Thanks!
The clicking is very indicative of worn starter solenoid contacts:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old Sep 23, 2009 | 10:05 AM
dixiemuddtoy's Avatar
I agree, its probably the starter solenoid on the back of the starter motor. don't try to replace just the solenoid, its cheaper to get the whole starter with gear box.
BTW, 12.65 volts is kinda weak. Mine won't start at less than 12.
and all the smoke that came out was probably cause the motor was flooded, and you were burning off carbon. every time you turn the key on and off, the little noise you hear before the 'click' is the fuel pump dumping fuel down the intake.
Replace the starter unit and you'll be fine : )
Old Sep 23, 2009 | 04:02 PM
BigBluePile's Avatar
Or just do the above^^^^ for a FRACTION of the price and retain your OEM starter that's better than the junk at the autoparts store...
Old Sep 23, 2009 | 04:07 PM
Junkers88's Avatar
X2 here. I bought an OEM replacement for 100$ when mine started this same crap because I wasn't confident that I could replace the contacts. Lesson learned, now I have an original starter out of an 88 sitting on the shelf and as soon as I get the contacts installed I'm pulling the old one out and using it as a trail spare. The original starters on our rigs will last forever, the contacts only make to about 200,000 miles though....... poor design on the contacts there Toyota...... poor design indeed. *laugh*
Old Sep 23, 2009 | 06:34 PM
91Toyota's Avatar
Wow! I appreciate the help guys! I will definitely look into it.
Junkers - Its funny you say the contacts only last 200k miles. I'm at 191k...lol.
Crazychris1871
Jun 27, 2016 10:38 AM
Cesarl74
Apr 23, 2016 06:07 PM
newzingo
Jun 24, 2015 01:50 PM
slider417
Jun 22, 2015 10:18 AM
Corey
Jun 10, 2002 04:23 AM
