truck starting problem
Old Jan 18, 2012 | 05:19 PM
phil in Tx's Avatar
do yall think the trouble could be with the pickup coil
Old Jan 19, 2012 | 01:09 AM
19864runnerHawaii's Avatar
sorry im kinda lost in all this, but if the coil is sending power, then all i can think of is the distributor.....
Old Jan 19, 2012 | 11:36 AM
dipasqualet44's Avatar
did you check the wires going to the coil for any damage?
Old Jan 24, 2012 | 05:36 PM
phil in Tx's Avatar
i finally got it running. it ended up being the pickup coil. i am gonna go ahead and change spark plugs and wires. hopefully it will start after that.
Old Jan 24, 2012 | 06:51 PM
  #25
87Toy22r's Avatar
Question M
My battery's volts go down when car is turn on. New battery and alternator, both got tested and passed (autozone)! Wirescoming from battery to alternator is good ,fuses,ground wires, also check and are good. Alt has the same v when car is on! I check it with a vmeter on the white cable coming of alt!!!charge and ebrake dash lights both on all the time!!! 87 toy carb 2wd 4cyl.
the1998sr5
Oct 19, 2016 12:48 PM
Crazychris1871
Jun 27, 2016 10:38 AM
bigblue82
10
Jul 6, 2015 08:27 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
slider417
Jun 22, 2015 10:18 AM
