Truck runs hot and ive replaced everything need help
Old Nov 10, 2011 | 04:07 PM
SR5's Avatar
SR5
so the truck runs between normal and 3/4 of the way up the temperature gauge and goes into red after a while.
ive replaced the temperature sensor, the thermostat a new radiator and a new electric fan.
Old Nov 10, 2011 | 04:10 PM
peow130's Avatar
Try the Carb thermostat. It opens at 180 instead of 195.
Otherwise, i'd check out your fan clutch and then check the flow of your radiator.
Old Nov 10, 2011 | 04:18 PM
turkey's Avatar
he said he has a new electric fan si i sur he knows its workin an has a new rad but should prob still check flow. and what about water pump?
Old Nov 10, 2011 | 04:37 PM
rworegon's Avatar
Check the water pump and the timing belt. I was running warm when the timing belt began slipping over the water pump pulley and not turning the WP at peak efficiency.
Is your head gasket in the early stages of going and leaking exhaust gases into the coolant, thus heating the coolant to abnormally high temps?
Old Nov 10, 2011 | 04:38 PM
Rob_A's Avatar
May be a long shot. But for me it was i tiny little hole in one of the freeze plugs. Replaced it and no more heating issues. Just look for liquid/vapor around that area.
Old Nov 10, 2011 | 04:53 PM
peow130's Avatar
oh its got a v6. disregard what i said, then.
Old Nov 10, 2011 | 05:05 PM
SR5's Avatar
SR5
i forgot about the water pump, and ya i think thats what it is, because there is now a knocking grinding noise coming from that area and i think that barings in the pump are out.
Old Nov 10, 2011 | 05:10 PM
rworegon's Avatar
If you do the water pump, also do the timing belt, the idler pulleys if they have lots of miles on them, and the TB tensioner.
Old Nov 10, 2011 | 05:49 PM
93toyrunner2's Avatar
Have you bleed the air out of the system? Mine had the same problem, and it took me 4 tries to get all the air out of it. Once I did, my gauge went to 1/2 or lower, depending on driving speeds.
There are several write ups on here - search "burp"
Old Nov 11, 2011 | 05:47 AM
ZUK's Avatar
ZUK
Does it overheat on the freeway?
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
saphirekosmos
Jun 22, 2015 10:26 AM
slider417
Jun 22, 2015 10:18 AM
Dr. Evil
Jun 16, 2002 07:52 AM
