Trouble with my oil pressure switch.
I have a 1994 Toyota 4x4 extended cab with the 22-re engine. My oil pressure guage was all over the place and I was told I should replace the switch. I went to Autozone and got a replacement but it isn't the same as what's in there. At least I don't think it is the same. The new one is pretty small. The thing I think it replaces is much bigger and has a brass housing around it. The threads where it attaches to the block look the same and the clip will attach to it. Are aftermarket replacements smaller or did I just get the wrong part. I am rebuilding a rebuild from he77 and I could sure use some help before something else goes wrong.
Thanks in advance,
Jeff
Thanks in advance,
Jeff
There are two different oil pressure senders for the 22re one is for a gauge and one is for a light. Dont plug in the sender and turn the truck on untill you are sure you have the right one or you could fry your gauge. Post a picture of the two if you can.
Welcome to Yotatech Jeff!!!
There is two different senders for the 22R-E. If you have the SR5 cluster which has an actually gauge for oil pressure and a tach then you'll need the "bell" shaped sender. The regular gauge cluster which just has an oil light is a smaller unit.
SR5 Guage switch:
Standard Guage Light Switch:
Anything else you need, please utilize the search feature and a lot of your answers will be found there!
SR5 Guage switch:
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
