transmission temp gauge sender palcement?
Where should I install the sender at? I'm too lazy to search right now, sorry. I figure just outside the transmission before the cooler would be best. 22re with an A340H automatic trans.
Wouldnt you want it right after the cooler instead of after, that way you know that the cooler is doing its job...
idk, Now that I think about...would make sense to be right before it also...
after instead of after, huh?
I would assume you want it before, to see what the operating temp is. Then again, it should be pretty consistent.
Also, I am going to be installing an oil pressure gauge. When I pull the stock sensor, won't that kick the dummy light on, since it will no longer be getting a signal? How can I make it so the dummy light stays off, unless needed and get the reading for my aftermarket gauge?
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
Poncho0206
Jul 10, 2015 06:21 PM
