transmission Fix lube
Old Jun 24, 2009 | 01:40 PM
Flash319's Avatar
So I swaped in another w56 I had laying around that I thought just had a bad input seal. I replaced the seal, put new Lucus synthetic 75-90 in and bolted back in the truck. Well to my surprise (not really) whinning again. No where near as bad as the one I took out. The whine goes away in 4th and it shifts and drives very well. I am thinking one of the driven shaft bearings is going bad but I will wait until it gets really bad then swap again...
My question is has anyone had any luck with any sort of trans fix-it (magic) stuff? I never buy any of this type of crap but I thought I might try something.
Old Jun 25, 2009 | 10:19 AM
Flash319's Avatar
No one has any luck with this kind of stuff?
Old Jun 25, 2009 | 10:25 AM
Elton's Avatar
it prob wont work or its soo thick it just makes it seem like it did work
Old Jun 25, 2009 | 10:41 AM
Duelertoyota4x4's Avatar
its basically a band-aid for a broken leg.
It might buy U some time..but its gonna go eventually.
Old Jun 25, 2009 | 11:46 AM
Flash319's Avatar
Oh ya I am well aware that it is going to go. This is the 5th trans that I have. I now have 4 "sloppy joes" in the back yard. I have had them in and out of different trucks but they all fail the same way. I guess you can't expect a manual trans to last much more then 400k km.
Wait for scrap to go up then chuck them all.
Old Jun 27, 2009 | 03:06 AM
GDR's Avatar
GDR
Its the front main bearing that goes bad. It gets the least lube.
4 th is quiet because its 1 to 1. Input and output shafts are connected so no power is transmitted down to the counter shaft which puts load on the bearings.
I took my "Sloppy Joes" apart to make a "Good Joe". The front and rear main bearings are the same so I used the good rear for the front.
Old Jun 27, 2009 | 04:11 AM
Flash319's Avatar
Thats a good idea. I might have enough parts to make a good one. Thanks.
chuckross1957
Jun 28, 2019 10:19 PM
Tigbucket
Jul 30, 2015 07:29 PM
HookahRoo
Jul 20, 2015 07:06 PM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
