Trailgear SAS'd 4Runner - 63" rear springs low
Old Jun 29, 2020 | 02:32 PM
mass-hole's Avatar
My 1995 Runner has a 3" Trail gear SAS that the PO installed. They also did a 63" Chevy spring conversion in the rear. The spring perches and shackles were installed correctly, however, the rear is sitting about 2.5-3" lower than the front and is also dangerously close to bottoming out the rear shocks just sitting in my garage.
What is the best option to get the rear lifted 2.5-3"? Would an aftermarket GM lift spring, like the ones Deaver makes, work to get it up higher? I would like to avoid using blocks.
https://deaverspring.com/product/che...f-road-spring/
Old Jun 30, 2020 | 11:20 AM
rattlewagon's Avatar
If you dont want to use blocks, a 63" lift spring sounds like a reasonable next step.
Lets see some pictures of your rig.
Either that or lower the front.
Old Jun 30, 2020 | 12:56 PM
mass-hole's Avatar
Thanks for the reply. I called Deaver today and they said it should work fine, but I don't know if they have ever tired it. Thats a lot of $$$ just to give it a shot.
I am thinking about lowering the front. The front is already as low as it will go with the default Trailgear stuff though. Its on the 3" spring and 5" shackle. So I suspect I can only drop it 1/2-1" with shorter shackles. I am looking for a shorter shackle with the right dimensions(M18 bolt, 19mm thru-hole).
Old Jul 1, 2020 | 06:25 AM
bump530's Avatar
I running TG 4" HD springs in the front. I used the 4 leaf 63s with a add-a-leaf to get mine to sit pretty level.
by https://www.flickr.com/photos/46020557@N04/, on Flickr
Old Jul 1, 2020 | 08:01 AM
mass-hole's Avatar
What size shackles and blocks are you on? I have a 1" block and 6" LROR shackle on the rear. I just dont think an AAL is gunna get me 2.5"
Old Jul 1, 2020 | 08:28 AM
bump530's Avatar
No blocks (other than the cut down factory overload) with 7" shackle. I think it added around 2" to mine. Its been almost 6 years since I did it so I don't remember exactly. If the front springs are new, they will settle.
Old Jul 1, 2020 | 08:38 AM
mass-hole's Avatar
The springs are not new, a few years old. The previous owner daily drove it like this.
Old Jul 1, 2020 | 08:49 AM
akwheeler's Avatar
your options to lift the rear are:
longer shackles
add-a-leaf
re-arched springs
new "lift" springs
Zuk mod
lift blocks
air shocks
or combinations of the above.
I don't recommend the air shocks AT ALL.
Pay attention to your pinion angle whatever you do so you don't end up eating u-joints on a regular basis.
snicklefritzy333
Apr 20, 2014 12:08 PM
ATVTRAILRIDER
Jun 13, 2011 06:34 PM
Dave the welder
Aug 5, 2009 05:27 PM
84Yota
Sep 12, 2007 04:04 PM
rob84runner
Aug 29, 2007 10:36 AM
