tow package
Old Oct 30, 2017 | 07:07 AM
parkerd's Avatar
tow package
Hi all
Just bought a 95 4runner SR5 with 4.56 gears/5 speed/31x10.5's....was there a tow package from the factory and what did it consist of?
Thank you all...
Old Oct 30, 2017 | 07:08 AM
dropzone's Avatar
Fossilized
dunno if there was a tow package but I wouldn't count on towing a bunch with a 2nd gen
Old Oct 30, 2017 | 07:39 AM
RJR's Avatar
RJR
My '94 came with a class II hitch and a wiring harness tucked up under the left rear fender, along with the interface box that takes the amber turn signals and red brake lights and combines them onto a single circuit for trailers. I assume that's what constituted the "towing package" back then.
I've towed a 2200 lb pop-up across the Colorado mountains several times with mine. As @dropzone says, it's not the ideal tow vehicle, but if you keep the rpms up it will get the job done. It was very stable at 65-70 mph. I don't think I'd go beyond 2500-3000 lbs however, at least not for any distance.
Since I got the '06 with the V8, I don't tow with the '94 anymore.
millball's Avatar
I think it consisted of a class II hitch and a straight line 4 pin type lighting harness.
Old Oct 30, 2017 | 08:26 AM
parkerd's Avatar
Thanks for the replies...just wondered about heavy duty brakes/radiator from factory...do not plan on towing.
Old Oct 30, 2017 | 08:49 AM
RJR's Avatar
RJR
I doubt there's anything special about the brakes, because the parts stores never ask about towing packages when I buy brake pads. I suspect the radiator is the same. These things cool well as long as the plumbing is clean, etc. I towed that trailer over Monarch pass multiple times - 10 miles uphill at 4200 rpm in 2nd gear. The temperature needle never budged. Brakes were adequate for that weight trailer (assuming downshifting on long downhills), but above that weight you'd want trailer brakes, anyway.
Old Oct 30, 2017 | 08:59 AM
gandude's Avatar
It also came with oil cooler
It also came with oil cooler,. At least for 1990.
Old Oct 30, 2017 | 02:35 PM
gandude's Avatar
for 1990 sales brochure
see bottom left.
Old Oct 31, 2017 | 12:41 AM
millball's Avatar
Can anybody produce any Toyota part numbers for these supposedly 'heavy duty' radiators that are different than normal???
Old Oct 31, 2017 | 08:27 AM
dropzone's Avatar
Fossilized
see bottom left.
the brochure you posted lists trucks...didn't see 4runners...
Old Oct 31, 2017 | 07:37 PM
gandude's Avatar
Yes, the brochure is for trucks only.
don't have one for 4runners. Trucks should be close though. My post above was for 2wd trucks. 4wd trucks don't list a tow package, and refers to the towing guide.
Below are the towing guide specs including 4runner for 1990
