Torsion bar clocking?
#41
If u know everything about these trucks then you would know that a die grinder won't fit. And cranking them does not do the same thing clocking will lift it the same way but without the added tightness that comes with cranking them. Of course they will have to be cranked somewhat clocking them will just lower the amount you would normally have to crank to achieve the same amount of lift.
#43
lol tofer, I wouldn't do anything with the ride height until those springs settle. I think I remember seeing someone say those springs settle at least a 1/2" to an inch. They will be the same ones I go with.
#46
you can see that the back still sits a little higher and thats without the motor still and now with the 1.5 inch ball joint spacers but it looks a lot better. my torsion bars are cranked to 1.25 inches of the bolt are exposed at the top, it used to be 1.5 inches before. My friend has 2 of these trucks and on one he had the bolts cranked to where only 1 inch was exposed and the other where 1.5 inches were showing. does anyone know what it is stock or what the limit is?
#47
doesn't look like it's sitting that bad
I'd let those new springs settle in; I bet it'll be pretty darn level after a few months of driving
maybe haul around a few bags of sand in the back for the first couple months to help speed up the settle-in process
#48
I think you should wait till your engine is back in to make any adjustments. And those new springs should settle a little, then maybe youll be at our 2". Also, the rear fenders are cut lower from the factory making the back look lower than it really is.
#49
Yea I have been measuring from the lines on the body not the fenders. So far the measurements from the body to the ground on each corner are.
FL- 39"
FR- 37"
RL- 40"
RR- 38"
So from the front right corner to the back left there is a 2" difference. And everything is symetrical and I don't know y everything is off by an inch both torsion bars are cranked to where there is 1.25" of the bolt showing and still my truck is about an inch higher in the rear and and inch lower on the right side ( has a gangster lean ) and I haven't even put the motor back in it yet. I'm kinda worried I'm gonna have more problems of it being off even more once my motor is back in it. Also the torsion bar on the left ( drivers side ) feels like it is a lot tighter than the other one when I tighten it but they are both adjusted the same amount so I don't know what is up with that.
FL- 39"
FR- 37"
RL- 40"
RR- 38"
#50
I'm kinda new here just started an account but when I bought my ome Tbars I did'nt adjust them by how much bolt was sticking out I adjust them til I had the right ride hieght. I just went and looked inder my runner too be sure but there is more bolt showing in the passenger side than the drivers. So in my opinion do'nt worry about the bolts and just make your front end level. of course thats after you install your engine because that will also change how it sits left too right not just front too back.
#55
#58
#60
Interesting, I've read both viewpoints on that; one that they only go in one way, and one that you can offset it. I forget how mine went in, I just used the FSM for tips. Mine definitely have different amounts of thread showing. For adjustment, I just measure to the frame/fender/bumpstops, etc.
