too early for timing chain?
i'm thinking about putting in a cam next summer, that is if we can melt some of the 3' of partly cloudy out there. my question is this: i'll have around 60K on it, is that too early to also throw in a new chain and guides, assuming normal wear at this point?
i'm up in ft.collins. it's not a problem, wrench all the time. thanks for your offer. i'll probably just do it with the new stick, was asking to see if i was overlooking the obvious.
I had to do one at 10k on a remanned motor after the cheapo aftermarket plastic drivers side rail came apart and threw the time...
Definitely do it while you have the head off and as mentioned, do it with a drivers side steel rail like the one engnbldr sells.
If you don't have steel guides in there then I would at least look at the plastic ones and see if they are still in one piece. If you have steel guildes I would leave it. It is a chain remember not a belt. The chain can take a lot as long as it is not running through your timming cover!
Replace the headgaskets and bolts? I didn't think you had to touch the head when you replaced the timing chain. Unless, there's a major difference on an '86 22re and a '94 22re. I didn't have to on mine. I got about 120 mi. outta my original timing chain before the guides started going.
Cheap insurance, go to the metal backed rail as well. Good excuse to change the water pump and gears in the oil pump while your there. I ended up pulling the head on my truck anyway to change the head gasket a couple of weeks after I did the chain, because I wasn't as careful as I should have been and damaged it causing a internal oil leak.
Yeah, I knew that. But, if you decide to let the timing chain be when you put in the cam you won't have to disturb the HG and bolts again come time to replace it. It just seemed like MMA_Alex was suggesting you would. That's all.
trumpfan: steel rails are the only way to go. i'll look at the hardened gears as well. small price to pay for added insurance and peace of mind.
thanks to all for the good advice.
Sep 4, 2015 09:27 AM
