Tire size for best MPG all city driving
Old Mar 15, 2011 | 02:14 PM
MB4runner's Avatar
Hi, I have a 3.0 v6 auto, 4.88s, I want to maximize city driving fuel mileage. Currently I have 31 x 10.5 tires. Should I go to 235/75/15
or what do you suggest?
Old Mar 15, 2011 | 02:17 PM
charliestoytruck's Avatar
im not an expert at all but the bigger tires would do the same speed at a lower rpm, just works harder to get there, if all your driving is in city then small tires are better, if you run open roads then im not sure. . .
Old Mar 15, 2011 | 02:19 PM
Swimmerboy2112's Avatar
For what it's worth,
with my 4.10 gears and 2" lift, running 30's got me 20-22mpg and when i went back to 28's i get 19-20mpgs granted this is about a 50/50 mix of city and highway but something to think about.
Old Mar 15, 2011 | 02:24 PM
MB4runner's Avatar
Thanks guys thats what i think too, if taller is better for highway, so im assuming shorter is better for stop and go city driving.
And I do 100% city driving
Old Mar 15, 2011 | 04:22 PM
pinoaktwh's Avatar
Are you guys compensating your calculations for the tire size difference. Meaning your miles driven will be different on your odometer with smaller to bigger tires.
When you put bigger tires on your truck your odometer will show less miles driven(worse mileage), smaller tires will show more miles driven(better mileage).
Now granted bigger tires Will get you less miles per gallon because you have to get them going.
Just asking, most people I have found never adjusted for that change, making thier mileage math "off".
Old Mar 15, 2011 | 04:40 PM
good point i didnt do any ,math just thought of principle's at play. my mud truck is off road only so i measure the gallons to the mile lol
Old Mar 16, 2011 | 05:20 AM
JJ'89's Avatar
lightest, skinniest, highest pressure; wider means more aero drag, and more rubber scrubbing in anything but straight-ahead...heavier means more rotational inertia...
Old Mar 16, 2011 | 02:45 PM
T_F_E's Avatar
definetly go back to stock if you want mpg.
Old Mar 16, 2011 | 04:32 PM
MB4runner's Avatar
Thanks guys. This truck is new to me, I'm going to finish this tank on the 31s and then switch to smaller tires and compare the mileage. Then I'm going to due a tuneup and compare again. Ill post the results in a week or so!
Old Mar 16, 2011 | 04:36 PM
Yes i compensated for the speedo being off.
Old Mar 16, 2011 | 04:41 PM
peow130's Avatar
Skinny, light tires.
30x9.5 is a good size, and better in the snow than a 31x10.5.
Old Mar 16, 2011 | 04:46 PM
4Crawler's Avatar
With that engine/trans/gear combo, 31x10.50 was the stock tire size.
Old Mar 16, 2011 | 05:44 PM
InvaderTrax's Avatar
Yeah I wouldn't go with a smaller tire for those gears. If you don't care about having big tires, you could always find someone to swap their 4.10's and small tires for your stuff plus a decent amount of cash
Old Mar 17, 2011 | 08:09 AM
MB4runner's Avatar
Yeah I figured the 31's were stock, I guess my main question is: If I do 100% city driving, and I go down to 29" tires with the 4.88s will I get better MPG? Yes or no?
I think I will because it will use way less throttle and gas to stop and go all day long.
If I ever plan a long trip, I will put the old 31's back on for better highway mileage.
Old Mar 17, 2011 | 09:10 AM
coops2k's Avatar
since you are talking about using this tire for just street, guessing that you will have a 2nd set for fun, I would go with a good passenger car or light truck tire in a 225/75/15 that is designed for improved MPG.
here is a good read on how tire sizes can affect a car
http://www.caranddriver.com/features...sted-tech_dept
BushPig
Oct 29, 2022 06:26 AM
Whatever123
Sep 30, 2015 12:12 AM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
87blyota
Jul 8, 2015 09:16 AM
