tips for cleaning block surface
Old Jun 5, 2020 | 05:45 PM
Amos Elam's Avatar
Are there any tips for cleaning the old head gasket material off of the block surface without a bunch of crud falling into the engine oil and coolant passages? Or does it matter?
Old Jun 5, 2020 | 06:28 PM
arlindsay1992's Avatar
Hold a shop vac right in front of your razor blade as you scrape. Once you're done, blast whatever you missed out of the holes/passages with an air compressor.
Old Jun 6, 2020 | 09:40 AM
dbittle's Avatar
I have started plugging up those holes with bits of shop towel to stop debris from going down all the holes. Definitely chase out all the head bolt holes and also find a really good straight edge to check for warpage of the block surface. After you are done with the block, you can pick the plugs out of all the holes and start blowing everything out with compressed air.
Old Jun 8, 2020 | 04:35 PM
Amos Elam's Avatar
The cylinder heads are in the machine shop. The machinist told me I could use maroon scothbrite to clean the block surface. I’ve read so many opinions against that though. Because of all the fine dust that the pads will make.
Old Jun 9, 2020 | 03:59 AM
dbittle's Avatar
It will do that. The shop towel bits will catch most of the dust. I tape between the pistons and cylinder walls also and use a piece of granite slab with fine sandpaper to get everything flat and clean. Good luck with it!
Old Jun 10, 2020 | 07:19 AM
JJ'89's Avatar
Be careful about plugging holes, lest you fail to unplug or can't retrieve. Vacuum is good idea. Razor blade scraper & some gasket softener like PB blaster, etc (can't buy real effective stuff w/methylene chloride anymore). I personally will not use any abrasive like sandpaper, emery cloth, Scotch brite etc. around engines, gears, bearings etc
toyodabro
Jan 8, 2018 05:14 AM
voiddweller
Dec 31, 2015 03:39 AM
jpmountainboy
Jul 29, 2009 07:13 PM
spiderx
Jul 9, 2005 05:08 AM
