Timing Chain / Engine Noise A Reflection
Old Nov 25, 2007 | 09:46 AM
DanStew's Avatar
Well i buttoned up the 4runner and drove it around. It is running nice, but it seems i have lost a little power. But all in all this is what i found out.
Before tearing the motor compeltely apart check a few more things.
I had the dieseling noise when i started the motor up. I pulled the timing chain and it and the guides looked real new ,and there was no evidence of the chain slapping on the timing cover. So i changed the chain out and sealed it up. I now know it takes to tear into a 22RE. I now know the age of the timing chain and hopefully i get rid of the oil leak in the front of the motor.
When timing the engine i now know i have either a broken or dirty TPS. I Ohm'ed it out today and i get nothing between the IDL and E2. No resistance at all. So i guess that is one reason why the jumper on the diagnostic port does nothing to change timing.
I also found out the diesel noise was not the timing chain. It turns out the idle RPM was set really high on the motor. I dont have the tach on the motor so it really didnt sound that high. But when i put my tach/dwell meter on it, the motor was idling at abotu 1300 rpm when it was even warmed up. So i knocked it down and retimed the motor to 750rpm. When i start it up i do not get that sound anymore. Even after i let it set and get cold overnight. But the idle is slightly irratic, it will pulse from 750-800 . Not that bad, but i can notice it a touch.
So all in all the truck runs good, but it seemed to be a little less peppy compared to before i opened it up. So i think it is possible the timing being setback to normal makes it a bit sluggish cause i am used to the timing advanced a bit.
So all in all i am happy and dissapointed but in the end i have it together and running. So I will address the TPS in a week or so, i am tired and it is getting chilly otuside.
Thanks for all the help!!
Old Nov 25, 2007 | 10:11 AM
SoCal4Running's Avatar
+1
Why not advance it up a little more. I belive on mine stock is 5 deg but it runs way better at 8 to 9 deg. I only set it a 5 for smog checks then back up it goes.
Old Nov 25, 2007 | 10:20 AM
DanStew's Avatar
I am not so much looking for pwoer, but more MPG, i may tweak it a touch after i see what i am getting for milage like this.
Old Nov 25, 2007 | 03:08 PM
84sr5yoty's Avatar
It isn't going to run right until you get a new TPS or figure out why it isn’t working correctly.
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
83flatt
Jul 2, 2015 10:30 AM
hexrain
Jun 27, 2015 06:17 AM
paxanders
Jun 21, 2015 06:29 AM
