timing on 22ret
Old Mar 16, 2009 | 08:30 AM
omesohi's Avatar
timing on 22ret
ok i went to set the timing on my 4ruuner last night,i let the yot warm up and then jumped the te1 and e1 taps together then hit it with a timing gun but the timing was the same with or without the pins jumped.arent the jumped pins spose to sort out the timing or im i just crazy!
Old Mar 16, 2009 | 08:37 AM
BoostedRNR's Avatar
Are you throwing any codes when you jump the connectors?
Old Mar 16, 2009 | 08:43 AM
omesohi's Avatar
i got a code 11
Old Mar 16, 2009 | 08:46 AM
BoostedRNR's Avatar
Sounds like a problem I had. You might need to try and adjust your TPS and get rid of that code before you can set your base timing.
Old Mar 16, 2009 | 08:52 AM
omesohi's Avatar
is there any special way to adjust the tps?
Old Mar 16, 2009 | 08:53 AM
omesohi's Avatar
and what is a code 11 anyways???
Old Mar 16, 2009 | 09:02 AM
BoostedRNR's Avatar
I believe its a TPS code. You can search on how to adjust the TPS, but most people go to the 4crawler web sight for the info.
Old Mar 16, 2009 | 09:05 AM
omesohi's Avatar
hey thanks alot 4 the help
Old Mar 16, 2009 | 11:21 AM
abecedarian's Avatar
11 is "Switch Signal": TPS IDL contacts not closed, Neutral start switch on, or A/C on when diagnostic jumper inserted.
You may be able to rotate the TPS a little bit to see if the contacts will close and let you set the timing.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
