Time to rebuild
#48
#52
This is an oem supplier for Toyota. Same parts without paying for the name.
Timing Belt Kit Toyota 4 Runner V6 1988-1992 w/oil cool
#54
fixed the link, i was on my phone before, and copied what i thought was a short-cut(link).
anyhow, that company is in Lorton, Va. Direct link to there site
#57
hey there....checking in as I am helping my son (age 15) rebuild a 3vze also.
some parts sources:
AISIN water pump and oil pump....... www.autopartswarehouse.com
Timing kit ....DAYCO from www.advanceauto.com (had used discount codes)
freeze plugs, exhaust studs..... LC Engineering
Toyota engine overhaul gasket set / other stuff from www.dealerdirectparts.com
if you take the time to read through my son's thread (in my sig), you will see how I arrived at those parts from those particular places. hopefully I can be some help to you since his is an 88 as well.
some parts sources:
sweet, thank you very much!! Sendin out the injectors to WitchHunter today so i should have those back soon.
