Tightening torsion bars
Old Dec 29, 2008 | 05:47 PM
91 yota's Avatar
Originally Posted by abecedarian
IIRC, scuba's 91 has dual nuts on the adjuster bolt... (no way to make that sound 'clean')
mine is stripped on the frame not the a arm.
Old Dec 29, 2008 | 06:02 PM
abecedarian's Avatar
http://personal.utulsa.edu/~nathan-b...29torsionb.pdf
Is this what you're looking at?
Old Dec 29, 2008 | 06:06 PM
iamsuperbleeder's Avatar
I know we've ventured away from the original thread pupose , but please, if it's just your daily driver and you care about the longevity of your Toyota, DO NOT adjust them just to get a few inches of lift...
I speak from experience. When I first bought my 91 it was bone stock. My first oil change, I look at those adjuster bolts and thought, "Well well, I've got a wrench that'll fit those!". I cranked them as far as they would go, threw a set of cheap shackles under the back to level it out, and I was ride'n pretty and high, grinnin from ear to ear... for the first 2 weeks or so... then the STUPIDLY stiff ride got to me, DESTROYED my tires because it just completely annihilated the alignment, and both of my CV axles have shreaded boots (although that really wouldn't have happened if a hub hadn't have failed and stayed locked for 8 months ).
I have since loosened them WAAAAYYY down, not quite back to stock, but enough to get a comfortable ride, and so my old tires don't quite wear so quickly.
I've already got BJ-spacers sitting here at my house to install, and when they get thrown on, I'll loosen them a little more, put some taller springs in the back to level things out, and let's not forget, get a proper alignment
Old Dec 29, 2008 | 06:10 PM
scuba's Avatar
I think troy has a chance to make his own BJ spacers and was lookin for someone with some lyin around for measurements...
Old Dec 29, 2008 | 06:17 PM
  #25
well buddy, it you're read'n this, hit me up; I'll bust out the micrometer, install my copy of AutoCAD I got ahold of back in HS, and draw it up!
Old Dec 29, 2008 | 06:37 PM
  #26
scuba's Avatar
Its not delivery, Its digiorno
Old Dec 29, 2008 | 06:40 PM
  #27
lol, ummm, what?
ooooook.....
Old Dec 29, 2008 | 06:44 PM
  #28
And I thought I went on tangents....
Old Dec 29, 2008 | 06:51 PM
  #29
91 yota's Avatar
abe, i'm i freakin idiot. i'm sorry. i been talkin bout the sway bar. is there a hole i can go get in?
Old Dec 29, 2008 | 06:54 PM
  #30
oh, a frame mount for the sway bar? I've seen so many of those rust and break away...
I'd be willing to bet you can pick one up at any parts store... they're all just about the same...
I completely removed my front sway bar today depending on how you drive your truck, maybe you could do the same?
I'm not recommending it or saying go do it, I'm just throwing the option out there...
Old Dec 29, 2008 | 06:57 PM
  #31
so one of the blind-nuts in the frame is stripped for the sway bar mount?
probably the best thing would be to drill and tap it to the next larger size bolt. there isn't any easy access to those areas in the frame. you might even consider just going to a sae fasterner (non-metric) so you don't have to drill too much out.
Old Dec 29, 2008 | 06:58 PM
  #32
91 yota's Avatar
yea it looks like this one was rusted then broke.
Old Dec 29, 2008 | 06:59 PM
  #33
wait, is the strap-portion over where the rubber bushing goes rusted and broke, or is it broke at where the bolts go through?
I'm so confused 91... I say show some pics, lol
Old Dec 29, 2008 | 07:04 PM
  #34
scuba's Avatar
TOGTFO !!
mmm...pizzaa...
Old Dec 29, 2008 | 07:06 PM
  #35
91 yota's Avatar
your right, it's the threaded part in the frame that holds the strap thats rusted out.(that goes around rubber bushin) of course the sway bar goes thru the bushin.
Old Dec 29, 2008 | 08:53 PM
  #36
Matt16's Avatar
That's weird. This is what mine looks like, I only have one nut. Wow that didn't exactly sound clean either.
Old Dec 29, 2008 | 08:55 PM
  #37
scuba's Avatar
No abe, My torsion bar adjuster is normal...One nut on top...
Old Dec 29, 2008 | 10:11 PM
  #38
Matt16's Avatar
One nut is enough. Ask Lance Armstrong.
Old Dec 30, 2008 | 07:21 AM
  #39
scuba's Avatar
I know matt, Thanks for reminding me...
Old Dec 31, 2008 | 04:59 AM
  #40
22redub's Avatar
Do all of these torsion bar cranking tips still apply if you where to upgrade your torsion bars to Sway-a-way bars or Downey torsion bars? Can aftermarket torsion bars handle the crank-in lift?
ladybugRC
458
Aug 21, 2020 10:41 AM
choppe777
May 16, 2016 08:00 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
HiLuxer
Sep 9, 2015 02:43 PM
