Tie Rod / Pitman Arm / Bushings Question
Old Jan 3, 2009 | 09:43 PM
Tubbyfatty's Avatar
Heres your parts lovetharunner,
Tie rod outer, $11.09, $15.29 or $32.99. Id go with the $15 right in the middle
Pitman arm is $72.49.
http://www.napaonline.com/MasterPage...od+End+-+Outer
http://www.napaonline.com/MasterPage...itman+Arm+Assy
Old Jan 4, 2009 | 07:24 AM
lovetharunner's Avatar
Dang Shawn... thanks for the help. You rock! The more I think about it, this wouldn't be a good project for us to work on because I would have to drive a long ways. I am going to try and take on this project myself... so I may be calling you with questions.
I am wondering how long this truck will be safe to drive before something goes really bad? What about all the little rubber bushings? Will I need to buy new ones or will the new parts come with them?
I am trying to figure out an approach in my head before I do anything. I was thinking that if I were to replace pitman arm first I could use the constraint of the existing tie rod assembly to get the new pitman back in the same postion. I am not sure if I could use a similar approach to get the new tie rod to line up with the old. I am worried about having an upside-down steering wheel or wheels that look like this /\ when I am done. Any thoughts or tips?
I found this link and it seems somewhat helpful:http://personal.utulsa.edu/~nathan-b...g/16steer0.pdf
Old Jan 4, 2009 | 10:37 AM
Tubbyfatty's Avatar
Yea man, its no prob.
Ive drove to U of O with lower ball joints that moved a quarter of an inch, i wouldnt do it again but its duable.
The pitman arm is kinda tricky but it just takes time. The tie rod end will make one wheel go like this / or \, just need to make sure to mark it and count the number of turns when taking it off.
All those parts should come with new bushings, take a look at the parts before you pay for em, they should look like the pics in the links i sent you.
Shoot me a pm or talk to me on aim (if you have it).
bigjstang
Jun 2, 2025 03:56 PM
krimsonone
Sep 13, 2024 09:33 AM
Sep 4, 2015 09:27 AM
ripp96
Jul 25, 2015 02:32 PM
ptb12
Jul 5, 2015 01:49 PM
