Throw down time
Throw down time
I want to start off by saying thanks to all who have helped me with issues in the past. Without this site, I would not be able to afford to keep my 4 runner.
Now down to business. I have a couple of nagging problems with the runner. First, there is a hole on the underside of my bellhousing approx. 2" by 4". Will this cause any problems on a trail. I have a replacement housing, but the job of doing it would be a pain.
Second, my t-case makes a weird grinding noise at times: low rpm's in low gears in either 4HI or 4LO. It only does this when I let off the gas, say going down hill, and puts a stress back through the gears to the engine. It's a different t-case than the original, and I don't remember the original doing this.
(side note, trans and t-case were swapped 'bout 3 months back. No hole in bell housing on either at the time, and I still have the other t-case. the new tranny came with a case, so both were swapped.)
Third, an oil leak from some where other than the main seals and valve cover gaskets. Ideas and suggestions on where to look.
Lastly, there is a water leak somewhere from the roof. Is this common, and what is the most likely culprit, luggage rack, or sunroof.
Thanks for all the help YOTATECH has been.
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 6, 2015 07:45 PM
