Throttle sticking at idle
Old Aug 14, 2011 | 08:18 AM
BUST'EM504's Avatar
My throttle is sticking at low rpm but I can pull the pedal back and it will drop the rpms back down. Any easy fixes for this??
Old Aug 14, 2011 | 08:57 AM
T_F_E's Avatar
spray wd 40 in the throttle cable
Old Aug 14, 2011 | 09:12 AM
SCToy's Avatar
This happens in my 81 and I can see the throttle return spring is weak that is next to the carb. Haven't figured out a solution as the dealer does not list the part number at all.
Old Aug 14, 2011 | 09:14 AM
xxxtreme22r's Avatar
22r or 22re? mine kinda sticks because the cable itself is frayed a little and as mentioned above the return springs really wore out. Mine's a carb'd 22r with a weber. Rigging a return spring solved most of my issues, might not be as simple to do on a 22re though.
Old Aug 14, 2011 | 09:24 AM
BUST'EM504's Avatar
It's a 22 re I tried to play with the spring by the pedal but that didn't help. I will try the wd 40 and see what happens
Old Aug 14, 2011 | 09:30 AM
not just the spring at the pedal but on the throttle body as well.
Old Aug 14, 2011 | 09:40 AM
thook's Avatar
Go ahead and spray the WD40 on whatever, but I'd disconnect the throttle cable from the throttle body linkage and atleast try to pinpoint what's hanging up. I mean, it could be the throttle plate itself, but you wouldn't see it if you hadn't looked in there or cleaned it in a while.
Old Aug 14, 2011 | 11:10 AM
BUST'EM504's Avatar
Thanks guys I'm going to go pull some stuff apart when it cools off a bit
Old Aug 14, 2011 | 02:36 PM
peow130's Avatar
pull the cable out, and spray some carb-cleaner into the cable itself to clean out the garbage..
I did this, and it came out black on the other end.
Next, go buy some white-lithium grease and lube up your cable.
Blamalam
Mar 12, 2022 07:34 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
mtc1105
Aug 4, 2015 08:06 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
