Throttle Body.. hoods up.. need help.
Old Apr 16, 2007 | 03:06 PM
thegreydog's Avatar
Ok, So I have got a second. I am trying to pull the throttle body and check the TPS and clean. I have removed the vac hoses, TPS plug, and bolts and nut. This thing is stuck on here, any removal tips? Also, while I am here is there anything else that needs checked/Tested in dealing with idle or acceleration?
Old Apr 16, 2007 | 03:12 PM
4Rocker's Avatar
If all the bolts are out use a BFH, the aluminum likes to stick to gaskets.
Old Apr 16, 2007 | 03:16 PM
thegreydog's Avatar
any suggestion as where to hit it, I don't want to tear anything up?
Old Apr 16, 2007 | 03:20 PM
4runnerx3's Avatar
You can check the TPS without removing.
Old Apr 16, 2007 | 03:24 PM
thegreydog's Avatar
But if I need to adjust the TPS, is there a way I can get to the bottom screw?
Old Apr 16, 2007 | 03:25 PM
MudHippy's Avatar
Just bump it somewhere solid, it shouldn't take too much. Make sure you clean out all the little nooks and crannies inside that thing, and don't get the TPS wet. You can get to the TPS easier with the throttle body off.
Old Apr 16, 2007 | 03:40 PM
thegreydog's Avatar
removed... the intake is extremely nasty is the anything I can do to clean it? off to clean the TB and adjust TPS...
Old Apr 16, 2007 | 07:20 PM
thegreydog's Avatar
Damn bottom screw... We had to drill it and tap it to get it out. Does anyone know what size screw should replace it? Is there any certain way the cap on the TPS goes back on? And is there anything else I need to check while it is off? Is there anyway to get the sludge out of the intake manifold?
Thanks
Blamalam
Mar 12, 2022 07:34 AM
mussy01
Dec 13, 2016 08:20 PM
markwink
Aug 18, 2015 12:38 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
bryan34w
Jul 6, 2015 05:53 PM
