third member swap
Old Oct 27, 2007 | 10:41 PM
  #41
chroad's Avatar
Jon, glad the boltup worked out for you. It sounds like our experiences aren't the norm. Though that is odd that your non-CV shaft doesn't fit what looks to be the rule here, but at the same time, there always seem to be exceptions to the Toyota norm. Or, maybe there is yet something else we don't know about...
Old Oct 27, 2007 | 10:42 PM
  #42
chroad's Avatar
Originally Posted by MudHippy
ONLY 2 PATTERNS FOR ALL 1984+ PICKUPS/4RUNNERS/SURFS
1 FOR NON-CV 4 CYLINDER
1 FOR CV 4 CYLINDER,TURBO/V6 OR FJ60
I give up
Marlin never says that, and neither did you before this edit to your post. But no one posting here will miss it.
Old Dec 6, 2007 | 04:03 PM
  #43
de6w6it's Avatar
i would like to bring this one back from the dead to ask a quick question:
I have an 88 runner with a 22re, 5 spd, and 4.10's, and it has a cv rear shaft. i bought a 4 cyl third, and the flange on the third did not mate up to the yoke on my shaft. The 4 bolts were bigger on mine than fit through the third, and the centering lip on my yoke was straight, while the flange on the third was beveled. so, if i understand this correctly, if I got a third from a v6, it should have the correct flange size?
thanks for any help/info
dewitt
Old Dec 6, 2007 | 06:27 PM
  #44
gametom's Avatar
i think if you got one of those tripple drilled flange thingies that it would work not positive tho
Old Dec 6, 2007 | 08:42 PM
  #45
Djlarroc's Avatar
I'm pretty sure that flange will work, if not marlin will have what you need.
On another note, only 86-95 IFS fronts are interchangeable? I'm looking to get both axles w/e-locker out of a '99 4Runner. Will the gears work?
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
