Think i need a new rear axle???
Old 04-26-2010, 12:17 PM
bobuk's Avatar
Give my mate Tel a ring in the UK on 07759 272270. He's got loads of surf axles..same as 4runner.
Old 04-26-2010, 12:22 PM
McQuaid's Avatar
Good man.....I will do in the morning
we think a surf 1990 model will fit?!? I may have found one if them
Old 04-26-2010, 12:36 PM
bobuk's Avatar
1990 surf will fit - just check your axle code to make sure it has the same ratio diff if you're fitting a complete axle. (plate on bulkhead where it says axle/trans will be a Gxxx number probably G294 or 295 if lsd) if different you'll have to drop your old diff into it.
Old 04-26-2010, 12:46 PM
McQuaid's Avatar
Whereabouts on the bulkhead is this?? I have never seen this??
Old 04-26-2010, 12:59 PM
  #25
bobuk's Avatar
Open the bonnet look at the back of bay - should be an ally plate just above the back of the rocker cover on the bulkhead. To the left of where the heater hoses go through to the inside of truck. If not there's probably 2 holes where it used to be rivetted on..
Old 04-26-2010, 01:02 PM
  #26
McQuaid's Avatar
Hmmm.....got a feeling I'll see the two holes, any other way to check out if it'll be the same gear ratios?? What's worst case if I just fit it??
Old 04-26-2010, 02:06 PM
  #27
peow130's Avatar
Worst case: You'll have unmatching gear ratios and need to get one changed out. Best way to check your gear ratios if you don't have your plate deal would be to lift one side of the truck with the opposite wheel on the ground.
chock the wheels, release the parking brake, and put the truck into neutral.
spin the tire around 10-20 times and count the revolutions that that driveline makes.
Chances are it will spin between 4.11 and 4.88 times per wheel turn.
if it's closer to 5 you'll have 4.88's.
if its closer to 4, you'll have 4.10s or maybe 4.30's. the 4.30s are unlikely though, seeing as they were found in early model solid axle trucks.
Old 04-26-2010, 09:27 PM
  #28
bobuk's Avatar
This may help.
Old 04-30-2010, 06:41 PM
  #29
NYChopshop's Avatar
my recommendation: check out trail-gear and get their awesome rock assault axle housing and swap out your coil sprung rear for leaf springs. The time is right! Clean, new, and improved empty axle ready to accept all of the worky bits in your rear end.
http://www.trail-gear.com/rock-assault-axle-housing
Old 04-30-2010, 08:09 PM
  #30
NYChopshop's Avatar
go take a look at your rear end. There is what's called a 'third member' there that is removed from the driveshaft (propeller shaft) side of the differential. That contains all of the bearings and gears and what-have-you. If you remove the rear brakes, and slide out your inner axle shafts, you just un-bolt your entire third member and put the new axle housing in. All of the parts will simply bolt into place. You don't have to worry about the set up of the gears, its an entirely removable assembly in the carrier.
photos thanks to the guide at atarmor.com:
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
yourrealdad
07-21-2015 11:13 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Think i need a new rear axle???
