terminal t
Old Jul 3, 2006 | 08:39 PM
clint's Avatar
terminal t
1 have a 1986 22re does any body now where the terminal t connection is thank you
Old Jul 4, 2006 | 05:09 AM
clint's Avatar
i believe i have to short circuit the terminal t to properly set the timing so i hope somebody can tell me where it is thank tou
Old Jul 4, 2006 | 05:57 AM
Flash319's Avatar
It is in a little box beside the fuses under the hood on the passenger side fender. You need to shore TE1 to E1. If the engine idle does not change when you do that then your TPS needs to be set up first. Do a search and you will find.
Old Jul 4, 2006 | 07:06 AM
clint's Avatar
thank you flash319
Old Jul 4, 2006 | 07:40 AM
clint's Avatar
does anybody have a picture of where the te1 e1 are located please i am sorry for all the stupid questions this pass couple of days but i just wanna get my 86 4runner runnin so i can have some fum.
Old Jul 4, 2006 | 09:42 AM
clint's Avatar
somebody must no exactly where it is and colour please thank you
Old Jul 4, 2006 | 06:43 PM
Elton's Avatar
not sure if this will help Clicky
Old Jul 4, 2006 | 07:04 PM
MMA_Alex's Avatar
on the passenger side fender. Its a little black box infront of the fuse box. pull the cover off, and on the inside of the cover all the terminals are labeled. There should also be instructions on how to, and which terminals to short on the underside of your hood on a sticker.
Old Jul 4, 2006 | 07:15 PM
clint's Avatar
thanks mma alex i found the terminal t mine is on the drivers side the one you are talking about i think is on newer 4runners mine is a 1986 thank you very much though.
Old Jul 5, 2006 | 08:22 AM
Flash319's Avatar
I have heard of this a few times. My oldest truck is a 88. At some point the went from a plug, to a black box connector, to the black box on the passenger fender. EFI started in 84 I think and all the moving around stopped in 88. Weird....
Old Feb 23, 2011 | 01:27 PM
infamouslyb's Avatar
Im trying to set the timing on my 1987 Toyota with a 22re but everytime that I disconnect the T terminal the whole truck shuts off. I was told that it might be a short. Does anyone have experience with setting the timing on a 22re that might be able to enlightened this poor fool?
Bourbonblues
Dec 15, 2017 05:43 PM
dbollier123
Sep 29, 2015 05:23 PM
runnermedic
13
Sep 21, 2015 05:20 PM
some drunk guy
Sep 4, 2015 11:55 PM
terminator
Jul 27, 2015 07:13 PM
