temp. gauge needle drops when fan is turned on?
When the truck is idling at normal operating temperature the needle stays in the middle like it should. But when I turn the fan switch on the needle drops down to 0, while the engine continues to run normal temps. I've shorted out the sending unit wire and this caused the needle to rise then I turn the switch on and the needle stays in same position.
I've replaced the sending unit and fixed the wire connector but the needle still drops to 0?
I'm not sure where else to look right now? Where are the grounds located maybe I missed one?
Thanks
Thanks
the1998sr5
15
Jul 14, 2020 08:35 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
Poncho0206
Jul 10, 2015 06:21 PM
92, 94, accelerate, accelerating, civic, drops, gauge, needle, normsl, operating, tacoma, temp, temperature, toyota, yotatech
