Tailgate Capacity?
Old Oct 13, 2009 | 03:43 PM
Blue Bowtie's Avatar
Originally Posted by TNRabbit
I can tell you definitively that it is NOT a 1000 lb stump~
"It's not in front of me right now, but I seem to recall that the owner's manual for my truck says something about a 120 pound limit on the pick up tailgate. Good luck."
I don't think that's right at all. I sit on my tailgate all the time with no problem, and I weigh about 210. Time to time, me and a buddy will sit on it and he weighs around 180, and I've had no problem so far.
Old Oct 13, 2009 | 04:00 PM
Robert m's Avatar
i have had 4 people on my tail gate at one time ranging from 150-260 and it supported all of us with no problem. the suspension however didnt care for it too much as i was tucking about 2'' of tire.
Old Oct 13, 2009 | 04:07 PM
Teuf's Avatar
My 88 has ittybitty cracks in bed at the back corners, from tailgate weight issue. and a yzf 450 does NOT WEIGH 350 lbs. 260 wet more like it.
Old Oct 13, 2009 | 04:08 PM
85yota4x4's Avatar
Originally Posted by poynter
Thats pretty scary looking right there!
once you hit a dip that tailgate is gonna fly up and its gonna hit that piece of wood and its gonna leave you a nice little dent in the tailgate
Old Oct 13, 2009 | 04:12 PM
  #25
94Beast4Runner's Avatar
If your worried about the gate bending in the middle.
Take it to a welding shop and have them tack a couple of 1" square across the inside.
I know it wont help the hinges holding power. Go crazy and get them to sleeve pipe around the hinges.
Old Oct 13, 2009 | 04:37 PM
  #26
Agent Orange's Avatar
My wife's Suzuki LT230 can be ridden up into my 4Runner, no problem ever with the tailgate.
Old Oct 13, 2009 | 07:38 PM
  #27
Anybody else have any input?
Old Oct 13, 2009 | 08:40 PM
  #28
sb5walker's Avatar
Originally Posted by wyoming9
You could cut a piece of 1/2 plywood long enough to cover the bed and tail gate and up against the tool box.
That way the weight would be supported more even over the whole bed 2 vice grip c clamps could secure the back end while loading and unloading.
I think that's a good idea. I would screw&glue a 2x4 rib to the center of it lengthwise for added strength. May want to use mending braces or flat washers on the plywood side to keep screw heads from pulling through - but you'll have to use something to keep them from scratching the paint on the bed/tailgate.
Old Oct 13, 2009 | 09:40 PM
  #29
3000GTVR4's Avatar
I frequently load my sportsman 500 in and out of my 1991 SR5 shortbed. The quad doesnt like fitting into the truck, and the truck doesnt like it much either. The only issue i had with my tailgate was when the ramps slid out and the belly of the quad fell onto the tailgate. I bent the hell outa that tailgate! I also learned to buy a real ramp with safty straps and not use homemade ramps.
The weight of the quad is in the bed, not on the tailgate during transit though. My tires stickout so ican close the tailgate, but the weight is in the bed. I suggest removing the box to get the weight off the tailgate during transport. Or you can get one of those slimline boxes, only 8" wide rather than 12-15"
Old Oct 13, 2009 | 09:53 PM
  #30
peow130's Avatar
when i pull my quad out i just slide the belly across the tailgate..
it's never dented it at all >.>
Old Oct 14, 2009 | 01:23 PM
  #31
Well, I guess I'm gonna try it, and see how it goes.
Old Oct 14, 2009 | 04:56 PM
  #32
Jay351's Avatar
Do it!
Ive had 500lbs on my tailgate! Didn't know there was a weight limit
Old Oct 14, 2009 | 05:18 PM
  #33
wunbigtacoma's Avatar
my arctic cat 250 4wd bent mine almost in a u shape 1 cold day,which tells me mine is either aftermarket junk or that my 4wheeler was just to heavy that day
I8URSVT
Mar 2, 2021 06:23 AM
matmattmatthew
10
Feb 9, 2021 04:15 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
Jake28296
Sep 16, 2015 06:10 AM
