T-case fluid
Old Mar 8, 2008 | 11:43 AM
cutboggers's Avatar
Question T-case fluid
90's style 4 runner tranny/ t-case 5 spd. I drained the fluid of the t-case and out came ATF wich is what new chain driven t-cases have. But parts stores everywhere tell me to put gear oil in. any help?
Old Mar 8, 2008 | 12:17 PM
thook's Avatar
Put in whatever is recommended from the factory for the tranny/t-case unit you have. You'll need to identify that. Run a google search on toyota axle codes. The pages will explain how to make the ID. Then, search the FSM under transmissions for what goes in it.
http://personal.utulsa.edu/~nathan-b...nualtrans.html
Old Mar 8, 2008 | 12:20 PM
cutboggers's Avatar
http://personal.utulsa.edu/~nathan-b.../3troubles.pdf
whats this a joke?
Old Mar 8, 2008 | 12:21 PM
cutboggers's Avatar
calls for gear oil. some reason i think its wrong.
Old Mar 8, 2008 | 01:17 PM
bry-an's Avatar
if its a 4cyl it has a gear driven case , which would make gear oil more sensible.
Old Mar 8, 2008 | 01:37 PM
thook's Avatar
Originally Posted by cutboggers
I don't follow your questioning here.
And, if it calls for gear oil, why would you think it's wrong? You can always call a dealership serv. dept.
Old Mar 26, 2008 | 07:32 AM
cutboggers's Avatar
bryan - it's chain driven out of a 90sumthin 4runner. I can see the chain through the fill hole. i put gear oil in and it hasn't made weird noises yet i think i am ok.
Old Mar 26, 2008 | 07:43 AM
becaron's Avatar
Why don't you read the manual or get a haynes manual?
haynes will tell you right in the beginning what oil and how much.
Odds are it take the same gear oil as the transmission and diffs, although for my 96 T100 Haynes manual specified 75W-90 for the front, trans, and transfer, and either 90W or 80W-90(cold weather) for the rear axle.
I just bought 2 gallons of 80W-90 and put it in everything.
Old Mar 26, 2008 | 07:48 AM
cutboggers's Avatar
yeah it says gear oil. i was just going off of other chain driven cases. It does seem manufactures use the same for both though.
Old Mar 26, 2008 | 12:51 PM
tc's Avatar
tc
the automatic tranny tcases use ATF (it's actually shared with the tranny). EVERYTHING else uses gear oil.
http://www.4crawler.com/4x4/index.sh...ntheticGearOil
ladybugRC
458
Aug 21, 2020 10:41 AM
zanzabar0
Oct 11, 2015 02:56 AM
bradahman
Oct 1, 2015 09:24 AM
gentry
Sep 28, 2015 06:16 AM
