Switches For This
Old Aug 22, 2020 | 05:59 PM
subaruwrx88011's Avatar
Switches For This
I have a frame off build. Bought these door with auto windows. Looking for switches, however I haven’t come across ones that have this plug.
Does anyone know what switches go to these types of auto window plugs?
Old Aug 22, 2020 | 07:49 PM
arlindsay1992's Avatar
Year/model/trim of the truck? Year/model/trim of the donor vehicle the doors are off of?
The actual metal wire terminal can usually be de-pinned and plugged into another style plastic housing. Sometimes this will help you mix and match parts from other Toyota vehicles without having to hack up harnesses and plug.
Old Aug 22, 2020 | 08:16 PM
Co_94_PU's Avatar
You're missing (atleast) a sub-harness here.
In my 86 SR5 there is a sub harness between the door light and window switch, upstream of this sub harness in the door harness is the connection for the window motor. You're probably missing the door control relay also, it's not super important but it allows you to run the windows up and down for a short time after the ignition is switched off.
Don't forget to wire up your window motor circuit breakers...
Old Aug 24, 2020 | 05:14 AM
Thanks for the info. I will be on the look out for the sub-harness and all the other parts.
drguitarum2005
21
Nov 11, 2011 03:20 PM
jacksonpt
10
Sep 8, 2005 08:56 PM
505taco
Nov 7, 2004 09:28 AM
AKA.HULK
Sep 25, 2003 05:42 PM
