Swapping in new torsion bars
Old Sep 9, 2008 | 12:56 PM
Dunnder's Avatar
Anyone have some helpful advice before I tackle this job? I bought some new 25.5mm TB's from Sway-A-Way (Downey backordered mine till Jan) and I also bought new TB bolts and nuts from Toyota.
Im going to remove the old and install the new this weekend. It doesnt look to tough, but anyone who has done this before and has some advice would be appreciated.
Cheers
Old Sep 9, 2008 | 01:13 PM
abecedarian's Avatar
take your time, jack the front of the truck up and support it with jackstands, chock the wheels, be safe.
the bars should be marked in some manner for left or right, so make sure to not get the bars on the wrong side.
measure the vehicle to the ground so you can adjust the new bars to the same height.
a light coat of wheel bearing grease on the splines will help you get it out if you want to later.
bounce the bumper between adjustments to 'settle' the springs
Old Sep 9, 2008 | 01:47 PM
AxleIke's Avatar
x2 on above, and remember, a LIGHT coat.
When I did mine, I packed in the grease, thinking to reduce the chance of any squeaks. This is bad because there is no where for the grease to go, and you will not be able to put the bar in all the way.
Good luck!
Old Sep 9, 2008 | 01:48 PM
Good luck!
and then pulling the bar out is difficult because of suction.
RatOmeter
Oct 22, 2015 03:17 PM
Sep 4, 2015 09:27 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
