surging idle only in 2wd/mystery vacuum leak? 22RE
Old Mar 21, 2019 | 06:56 PM
rattlecan.ak's Avatar
Hi all.
Hoping someone can help me solve this mystery... I have a 1989 22RE, got this truck a few months ago and been slowly working out the bugs, but need some help on this issue. I’m getting a surging idle around 1000rpm ****ONLY**** when I’m in two wheel drive, coming to a stop/idling. It doesn’t happen all the time, and quits as soon as I throw it into 4x4. Been trying to pin down the exact variables contributing to the surging idle but it seems somewhat random. When it does happen, it’s usually when I’m at a stop, or coming to a stop, in neutral, but it has happened in first gear. If I’m at a stop and this is happening, it’ll quit for a moment when I tap the gas, but it eventually starts up again. But the problem doesn’t happen with every stop...
I saw a thread where someone had pretty much the exact situation, turned out to be brake booster failing. This was all happening and then my booster also ˟˟˟˟ the bed, I replaced it, thought that would be the end of it, but nope.... same symptoms (though now a working brake booster).
Tried the standard vacuum leak test with the engine running, carb cleaner etc but that turned up nothing. Really not sure where to proceed here, any help would be greatly appreciated! Thanks.
Old Mar 22, 2019 | 02:00 AM
ev13wt's Avatar
5 Year Member
Mine surges if the idle is too high and I press the brake pedal. The fuel cutoff (I think) will cut every 750ms (about)
In 4WD It just idles high.
Can also be the TPS sensor. 4crawler has a nice writeup to test that.
Link to another thread about it: https://www.yotatech.com/forums/f116...e-22re-195583/
Old Mar 22, 2019 | 06:55 AM
snippits's Avatar
On my 92 22RE that was doing it randomly, it was a bad idle air control valve that was causing the surging. Has not done it since I installed new one back in October 2018.
https://www.yotatech.com/forums/f116...stions-305617/
Old Mar 23, 2019 | 08:25 AM
Cool thanks. When my TPS went out on my ‘90 it had a real “violent” idle surge but it could be a similar problem. The surging is real fast and only about a ~250rpm jump. I’ll test the TPS though, thanks
Old Mar 23, 2019 | 08:26 AM
did yours do the same thing, in only 2wd? I looked into the idle air control valve but wasn’t sure the symptoms were the same. Probably needs replacement regardless, don’t think the previous owner did much maintainence on this rig. Thanks for the reply !
Old Mar 23, 2019 | 10:02 AM
snippits's Avatar
My truck is in my signature...2wd 5 speed, so I can't help you with 4wd.
Old Feb 12, 2024 | 06:45 PM
cliff4runner's Avatar
My 1990 4runner 22re has the same surging idle, only in 2wd. As soon as I put it in 4wd it idles fine. Did you ever find the cause??
HNH2016
Sep 6, 2016 06:22 AM
tmcaron
Nov 17, 2011 10:31 AM
dxx
Jun 2, 2011 08:15 PM
jinotown
Feb 8, 2011 06:07 AM
TMacKinnon
Jul 13, 2010 07:19 PM
