The surge is back...back again!
Old Oct 19, 2008 | 08:40 PM
  #81
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Yeah, Abe we've talked 'bout Hamer before. We are of the same mindset when it comes to them.
And we don't need to know 'bout your personal shimming problems. There are pills and operations bout stuff like that. Go to a dr.....lol
Old Oct 19, 2008 | 08:42 PM
  #82
But keep in mind. Like I said, that was on my v6. I don't know if your 22re has 1 or 2 copper washers
Old Oct 19, 2008 | 08:45 PM
  #83
abecedarian's Avatar
if it was Hamer... it was likely 2 pennies drilled out and ground down with the copper shavings sold for scrap.
*edit- sorry, yes. banjo bolt, two washers.
Old Oct 19, 2008 | 08:47 PM
  #84
lol. Lets not eeven go there. Thats a whole new thread. The Hamer Toyota haters thread.......
Old Oct 19, 2008 | 08:53 PM
  #85
91Toyota's Avatar
haha...yeah I'm talking about those two little copper shim thingys on BOTH sides of the fitting...I only have one on the intake side...not a big deal right???
Old Oct 19, 2008 | 09:11 PM
  #86
on my v6 1 was supposed to be on the inside of the banjo bolt, and 1 on the outside, IIRC
Old Oct 19, 2008 | 09:14 PM
  #87
typically, you'll see two washers one on each side of the banjo fitting- one to seal the fitting against the 'mount' and another to seal the bolt to the fitting.
so... now what?
Old Oct 19, 2008 | 09:15 PM
  #88
not necessarily a big deal, but if the banjo bolt is not centered in the banjo fitting, the holes in the banjo bolt may be partially restricted, limiting the fluid flow.
Old Oct 19, 2008 | 09:16 PM
  #89
now that we have totally straight and figured out.....wait, will there be a quiz on this later?
Old Oct 19, 2008 | 09:29 PM
  #90
91Toyota's Avatar
I sure hope not
lol...its centered...or at least I think so.
So, is there are a way to clean the AFM? I heard that your not supposed to touch the little thingys...whatever they call them.
Old Oct 20, 2008 | 12:36 AM
  #91
touching little thingys may make you blind...
oddly enough though, electrical contact cleaner might work.
Old Oct 20, 2008 | 10:41 AM
  #92
91Toyota's Avatar
I only touch my big thingy Alright...might give that a try!
Old Oct 20, 2008 | 10:52 AM
  #93
you really shouldn't be playing with your tranny shifter. You're trying to fix your truck, remember??? Stay on the subject AT hand, not In hand!!!! Geez, youngsters these days
Old Oct 20, 2008 | 08:00 PM
  #94
91Toyota's Avatar
Haha...okay for some reason my truck starts first try in the morning after its been sitting all night. But say I drive to school (2 miles) and leave at lunch (from 8-11:45 it sits) it won't start unless I give it a bit of gas.
Just throwing it out there. I haven't looked at the afm yet. Its my birthday tomorrow and I have to work...lol.
Old Oct 20, 2008 | 08:03 PM
  #95
I don't think you're giving it gas... I think you're giving it air, holding the pedal down.
Old Oct 21, 2008 | 12:04 AM
  #96
91Toyota's Avatar
True! Yeah i know its not carb'd
So should I still get a vac gauge? Where do I put it? And how much pressure should I be looking at? Thanks!
Old Oct 23, 2008 | 03:07 PM
  #97
91Toyota's Avatar
Okay...tested the AFM and it works fine. Looks like I should be looking for a vacuum leak now. I need a gauge. It will be a couple days before I get it though. And, the inside of the AFM is horrible. Its pretty corroded and has a bunch of white (I'm guessing the corrosion) stuff all in the inside. Not to mention its dirty. And I have a new air filter on my truck (just to make sure) lol.
Also, my idle still changes a little bit from time to time. Idle will be at 600 sometimes and it usually always stays at 750. I'm going to retime it in a little bit. Thanks!
Old Oct 23, 2008 | 08:21 PM
  #98
any particular reason why you think a dirty, corroded, white-stuff-covered AFM is fine?
smthwsn357
May 1, 2024 07:28 AM
wafoogalla
Nov 2, 2016 11:02 AM
Ditch Doc
Oct 27, 2015 03:20 PM
Gurr
Sep 12, 2015 09:51 PM
PBRaddict#1
Aug 22, 2015 11:34 PM
