Summer build/work
Summer build/work
So i don't have the photos uploaded yet, but I thought I would update you all on my summer project i got going right now. I have been needing to do my clutch as the throw-out bearing has been making some noise and the clutch has had some chatter now and again. picked up the MC heavy duty clutch kit and pressure plate bolts.
Other part of this work time was putting in my Detroit EZ-locker. I pulled my diff and took it to the shop and had them install it and setup the gears for me. I would have done it myself, but I am going to be driving a lot to college the next 4 years and I just wanted to make sure it was done right.
Only problem i had was the drain plug on the diff stripped out. buggered the threads on the housing. Hopefully going to get the tap tomorrow to clean them up and will be able to put it all back together tomorrow night. Got new plugs too. Anyone else have that problem?
The flywheel i am going to have turned tomorrow and have it by about noon, so i am hoping to get the trans and the new clutch in by tomorrow night. hopefully the diff tuesday morning. Flushing the diff, trans and transfer case fluids with Valvoline 80w-90.
One question: What's a good rule of thumb for breaking in the clutch? How many miles before I let's say: tow with it, and/or take it off road?
will post some picks soon!
of course this is not very intense but still working it a bit.
pictures
Dad cutting fill plug off.
i was tired
diff back from shop
you can kinda see the locker in there
there's the trans/transfer combo
no oil leaks, well, from the main seal hahaha
drain plug, whoops.
double wound shock springs
1200 pound pressure plate
hope to work finish up maybe tonight. thanks folks.
i was tired
diff back from shop
drain plug, whoops.
Nice, Alex! Didn't go cheap on the rear main, did you? I wish I'd gotten a better one than I did. Now, I have to wait until the next clutch job....and, it's the Marlin HD. That'll be a while...pfffth!
what do you think of the marlin HD? From the looks of it, I think it has to be one of the better ones on the market.
I really, really like it. It grabs well and it feels good. Especially since I have a new MC and slave. Flawless.
How old is your rear seal, Alex? Those aren't at all hard to change, eh.
flywheel
pilot bearing
clutch
got to wait for my fasha to get home so we can jack the trans up in there.
Finished!!!
finished about an hour ago. took it out for a drive and man, the clutch is so smooth! can't believe how great it feels. the locker is great. the slack isn't bad. It is hard to tell how well/smoothly it ratchets because it is down pouring right now and all of the roads are slick because it hasn't rained in a while. so i don't know that much. drove it about 2 miles and it feels great. will drive it a bunch more tomorrow. and i will post a picture of the beast that i was driving around when my 4runna was out of commission. A 1965 chevy C20. oh yeah.
alright, the detroit is leaving. the damn thing will never unlock. in the time that i have had it i think it unlocked 3 times and all the other times it just drags the wheels around the corners, with no ratcheting. got on the freeway the thing popped and one side completely lost power almost sending me into the lane next to me. I jumped the gun on this one. having them put the old spider gears back in it, and going to leave it open until I have the money of enough dedication to get an ARB for the back.
it sucked. gaaaaaaaaah
on the plus side, the clutch is amazing
I had it set up by 4 wheel parts. I installed the third in the truck I am going out their today and having them drive with me to see if it is working right or not. I jumped the gun and got what i paid for as far as i am concerned. I want to put my spiders back in until i can get a selectable locker. I don't plan on getting one right away, though.
So i just got back from 4 wheel parts and my ride along session with the mechanic. I backed out of the parking spot, he said, "hmm, it didn't unlock." Then I made a turn in the parking lot and proceeded to drag the wheels and have them squeal around the corner and he said, "ok, you can park it now, that is not normal." they told me to bring them the third on monday and they will completely disassemble it and figure out what is wrong. If they fix it, I will use it and make sure they give me my spider gears and bits back so I could go back to my standard diff if i want to. I am starting to be a little more optimistic now.
That's what i am thinking. I want it to work right and it obviously wasn't. they were very nice about it and they said bring it in, tonight i am pulling it again. I will take more pictures this time so I might be able to make a step by step instruction for guys who want to see how to take out the differential.
