Successful '93 OBD Reading
#41
Hey guys,It came back to me... there is something you could monitor that would be a + to many of us (different toyota engines), I'm a FWD/awd celica guy , I dont know for your 22r or 3vz-e ,but do you have analog oil pressure sensors on your engines? not oil pressure switch. in an st16x celica it drives a needle in the dashboard to GUESStimate the oil pressure, it's not graduated and the needle refresh rate is slown down. we probably could repurpose it and map it's real psi value in accordance to its signal. it's a stock toyota sensor that is found for cheap in junkyard , it threads in place of oil pressure switches in a breeze on mostly any toyota engines. could be usefull to add to a generic monitoring system??
#42
Some progress on the interface
Pretty much just placeholders right now, this is not actually hooked up to the car. Plus I'm totally open to suggestion with the items displayed. It will also be very easy to change anyway
Since this is a monochrome screen, I'm going to split the graph up into 4 separate ones instead of all of them overlayed on top of one another
Hope you dig it
Hope you dig it
wilshire
Apr 26, 2012 07:18 PM
