Sub+65mph=top Off
Old Mar 17, 2007 | 09:05 AM
DeathCougar's Avatar
punc?tu?a?tion /ˌpʌŋktʃuˈeɪʃən/ [puhngk-choo-ey-shuhn]
?noun 1. the practice or system of using certain conventional marks or characters in writing or printing in order to separate elements and make the meaning clear, as in ending a sentence or separating clauses.
2. the act of punctuating.
3. punctuation marks.
run-on sentence
?noun 1. A written sequence of two or more main clauses that are not separated by a period or semicolon or joined by a conjunction.
Also called fused sentence.
How did your stereo cause all your bolts to rattle loose? And I am confused about your back window....did it hold the top on while it as trying to fly off? And did it "break" (not brake)?
Old Mar 18, 2007 | 12:18 PM
just a 22re's Avatar
No the rear window didnt brake for some reason i dont know why. Yes the window held the top on but it was only like 2 sec. The sub i belive caused the top to come off just cause there's nothing else back there (that i know of) that would or could make the bolts come out. There hows that for gertting my typing right??
Old Mar 18, 2007 | 01:12 PM
that statement says it all lol
Btw...
Brake - [breyk] noun, verb, braked, brak?ing.
?noun 1. a device for slowing or stopping a vehicle or other moving mechanism by the absorption or transfer of the energy of momentum, usually by means of friction.
2. brakes, the drums, shoes, tubes, levers, etc., making up such a device on a vehicle.
3. anything that has a slowing or stopping effect.
4. Also called brakeman. a member of a bobsled team who operates the brake.
5. Also called breaker. a tool or machine for breaking up flax or hemp, to separate the fiber.
6. Also called press brake. a machine for bending sheet metal to a desired shape.
7. Obsolete. an old instrument of torture.
?verb (used with object) 8. to slow or stop by means of or as if by means of a brake.
9. to furnish with brakes.
10. to process (flax or hemp) by crushing it in a brake.
?verb (used without object) 11. to use or run a brake.
12. to stop or slow upon being braked.
13. to run a hoisting machine.
Lol, I had to. Yes I am a grammar Nazi; so sue me!
Old Mar 18, 2007 | 01:14 PM
btw, i have a 2 subs as well as 2 amped 330 watt 6x9's in my quarter panels, and the bolts have never loosened up in 3 years. Be sure to double check your bolts when you put the top on, and torque them in the correct sequence. It its a really hot day, be sure to check the bolts when its cold again, say in the morning since heat causes things to expand.
I doubt your stereo caused the bolts to rattle out, even if you had it at max volume. In which case....you're now deaf lol.
Old Mar 18, 2007 | 01:50 PM
  #25
91TPU's Avatar
Originally Posted by Bassinfool
IF I only had a 13" monitor that space would only be about .75"!
very true, even at that sense, 3/4 of an inch is still excessive for it to move. and i would assume that most people viewing YT are on monitors larger then 15 inches, as my comp sucks and i still have a 17 inch monitor.
Old Mar 18, 2007 | 02:01 PM
  #26
lol ok ok so i cant spell or type bite me!! lol but yeah i will be checking them bolts untill it gets hot out here so i can take the top off again
pickle6415
Apr 14, 2021 06:20 AM
pickle6415
Dec 25, 2015 07:34 PM
LotOMiles
Sep 14, 2015 11:45 PM
highonpottery
Sep 14, 2015 12:46 AM
Boomer8404
Sep 10, 2015 09:01 AM
