Stupid question about oil filters
I just hit 500 miles on my rebuild and when I changed the oil and filter no oil came out of the filter. My old motor would pour oil down the side of the block when you pulled the filter off. Oh yeah it's a 22re.
it dont matter what oil filter you use it will drain back if it sits long enough before you take it off. but, i agree w/ elton, do not use fram or bosch. i have seen frams take out an engine from the paper eliment coming apart and clogging oil passages.
That isn't necessarily what you're reading into it (or shouldn't be at least). Filters with a good anti-drainback valve (OEM, Wix, Motorcraft) will retain oil in the filter longer than those with poor ones (Fram, Bosch). Ideally, the oil would stay in the filter forever and then leak out all over your block when changed. This is not an ideal world though so view it as good when the oil leaks and bad when it comes off dry (unless the engine has been sitting for a couple days or more).
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
