steering wheel at 45 degree angle when driving
Old Jul 22, 2013 | 05:58 PM
kyle156's Avatar
My steering wheel sits at a 45 degree angle when I'm driving how can I fix this its an 87 pickup 22r 4 wd
Old Jul 22, 2013 | 06:20 PM
SPARKS89's Avatar
Check to make sure nothing is bent and your tie rod ends are good. Provided you're not having any issues with alignment, pulling or anything abnormal with the steering I'd say you just have your steering wheel indexed wrong.
Get the tires going straight ahead and park the truck. Then just pull the steering wheel and re-index it to where it's straight. Put it all back together and take it for a drive.
Old Jul 22, 2013 | 07:24 PM
kyle156's Avatar
Thanks for the help pulled the wheel off put it on straight. Drove it and the wheel sits straight also fixed my horn while I had the wheel off
Old Jul 22, 2013 | 08:27 PM
SPARKS89's Avatar
No problem! Glad you got it taken care of.
Old Jul 22, 2013 | 11:30 PM
RSR's Avatar
RSR
Did you by chance recently change your pitman arm?
That's the most likely cause. Either you installed it one groove off, or the previous owner did. Definitely want it installed correctly. I found a small straight edge or ruler worked best for getting it lined up...
Old Jul 23, 2013 | 05:44 AM
kawazx636's Avatar
If you simply take the steering wheel off and rotated it over a few splines, your turn signals will not work properly (Unless the steering wheel was installed wrong to begin with). The turn signals function based on where the steering column is, not the steering wheel so your turn signals will either not engage properly or disengage early. The adjustment should be made in your pitman arm or draglink to align it properly.
Old Jul 23, 2013 | 04:28 PM
RSR's Avatar
RSR
I took mine off as the PO or some mechanic installed the pitman arm one notch off and then apparently just adjusted the steering wheel. I didn't make note of turn signal engagement before fixing -- I actually swapped in a new pitman arm while changing out my whole steering system idler arms, tie rod ends, pitman arms, etc, when I first purchased the truck...
But after, (just checked actually) my turn signals engage at 1/4 turn in either direction.
But to the original point, if your steering wheel moves out of alignment, and you haven't changed anything, then you first need to identify and fix that problem, not just adjust the steering wheel...
Old Jul 23, 2013 | 04:38 PM
StewsRunner's Avatar
The steering wheel on my old truck was off because I messed up when installing the pitman arm and my blinkers were in fact off as well... The whole "straighten the wheel out and the blinker goes off aspect" was off and the blinker would not always go off. But like previously stated, if you haven't touched anything on the front end, its probably the steering wheel..
Jun 1, 2021 01:51 PM
skoti89
Jul 6, 2015 07:45 PM
Jnkml
Jul 6, 2015 01:20 PM
