Starting Problem
Starting Problem
1993 Toyota truck, 4x4, v6, manual. When turning the key over to start the truck receive a single click and the engine does not turn over. This is an intermittment problem - if I continue to turn the key off/on, the motor will eventually turn over and start. Does this regardless if I depress the clutch or press the no-clutch start button. Is worse at first start in the morning. After warming it does not happen as much. Replaced battery thinking it was a weak battery, but no improvement. It is getting worse with time. Any thoughts would be appreciated. Starter? starter relay?
I would have to say its the starter. If you can hear the starter spinning but no turning of the engine it may be the starter sylinoid. Otherwise, the starter took a crap on ya.
Thats just what I think, may want to see what others say.
The copper contacts inside the starter solenoid are prone to wear, easy and inexpensive to replace:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
