Starting issues, very weird
Old Oct 3, 2010 | 05:03 PM
95blackToy's Avatar
Exclamation Starting issues, very weird
Alright my truck hasnt been starting when its cold. So i tried to take the cold start injector time switch connector off and it pulled the insides of the switch out. Well there are two metal prongs. If i jump from one prong to the positive of the battery it makes the cold start injector click. If i jump the other prong to the battery it turns the motor over. Well i jumped the one which makes the injector fire and then turned the key and it started, runs good if i dont give any gas, if i give gas it backfires and misses and dies sometimes. I disconnected the jumper and it runs good for a little bit and then dies. Any ideas or suggestions?
Old Oct 3, 2010 | 05:12 PM
95blackToy's Avatar
seems to be loosing all fuel when i disconnected the wire
Old Oct 3, 2010 | 05:23 PM
95blackToy's Avatar
am i just bypassing the switch when this happens? Can i run it like this for a while till i get a new switch?
getting a video up in a few minutes
Old Oct 3, 2010 | 05:43 PM
95blackToy's Avatar
http://www.youtube.com/watch?v=qoEMxAAlN6Y
running at about 500 or less rps, then i give it gass and play with the throttle and it misfires and runs so bad there is no way you could even drive it. then at about 0:48-0:50 i unplug my jumper and it runs then dies.
Old Oct 3, 2010 | 06:04 PM
95blackToy's Avatar
nothing?
Old Oct 3, 2010 | 06:37 PM
95blackToy's Avatar
next time i tried it started right up without jumping it but would die after about 10 seconds, i jumped the fuel pump ports in the diagnosis box to make the fuel pump run and tried starting it while it was jumped and it was run. Bad MAF? can i run it like this for a couple day?
Old Oct 4, 2010 | 05:30 PM
95blackToy's Avatar
well i accidentally broke the cold start time switch strait off. It was siliconed on. Now it runs much better and starts up with no problem
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
