Starting 340h to R150F swap, speed sensor question
Old Apr 10, 2011 | 10:17 AM
Booosted Supra's Avatar
I found this AWESOME write up on the net about the whole swap
http://sites.google.com/site/wastedf...nsmission-swap
Only thing I didnt see was info about the speed sensor. It looks like the 340H has an electrical one and the R150F has a mechanical one. How do you go about setting up the speedo? Is there an interchangeable part out there? I tried searching but came up with dead ends
Old Apr 10, 2011 | 06:15 PM
... no one??
Old Apr 10, 2011 | 07:13 PM
Dras16's Avatar
I know this isnt exactly what your looking for but maybe the people that make this might make something that would work for you. https://www.yotatech.com/forums/f116...l-pics-195986/
Numbchux's Avatar
Give us some information if you're going to be impatient about a response.
I'm assuming this is in the 4runner listed in your sig, but I hate when I have to make a big assumption like that with something like this.
The A340H that was in my '87 Turbo 4runner had a cable speedo. That cable threaded right into the RF1A tcase that I now have in there.
Old Apr 11, 2011 | 05:31 AM
Inpatient? I posted first thing in the AM and asked again late at night? Assumption of the truck in my sig? Yeah I just post up mod lists and years of vehicles for fun guy.
Anyway WITH OUT THE ATTITUDE=) I the R150F HAS the screw on type speedo, my 340H has the electronic. For the record I def did state that I wanted to FROM mechanical to electrical so unless you know something I don't then I think the question was pretty straight to the point
Old Apr 11, 2011 | 05:33 AM
Thanks for the info Dras, thats the type my R150 has, I need to figure out how to go electronic
Old Apr 11, 2011 | 06:58 AM
Dras16's Avatar
You might be able to pull out the gear part out of the tranny and then put your electronic one in there. There is a little bolt with a tab that holds it all on there.
I dont know if they can be directly swapped over but its worth a try.
Old Apr 11, 2011 | 07:56 AM
justin_4runner's Avatar
so i just got done doing what u are trying to, the trans that i got for my 4runner had the electric sensor, i found a 5 speed with a cable out put and bought that, it was a strait swap, but i did find out that its off at 60 it shows 55 and at 70 it shows 63 and at 80 it shows 70. but at one time i had found that u can order different gears for like 7 bucks to adjust them as needed, just look for a trans that comes from a trany about the yr your putting in, some have the shall 1'' hole and some have a 2'' hole guessing on size but u get what i mean.
Old Apr 11, 2011 | 08:14 AM
Dras16's Avatar
I believe he is doing the opposite. He put a trans with a cable speedo into a truck that originally came with an electronic speed sensor. Please correct me if im wrong. But like you said I believe that you can just switch the gear drive mechanism over.
Old Apr 11, 2011 | 08:21 AM
Dras16's Avatar
Ok so with a little searching I think I found what you need. This is an adapter to go from you transfer case. It threads right into your t case and then has a plug for your speedometer. http://www.marlincrawler.com/transfe...eed-sensor-mci
Old Apr 11, 2011 | 08:39 AM
RMA's Avatar
RMA
that sensor from marlin will work .. but all you need is the sensor from 1992 -1995 from a 5 speed its electric.
something like this ..
just so you know i have not used this sensor from ebay.. im just posting the pic.
http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories
Old Apr 11, 2011 | 02:42 PM
thanks for all of the good info guys, Dras that adapter is pretty sweet, like RMA said though I did look under my buddy's 92 pick up today to find an electronic sensor so I am going to go with that, looks like 92-95 will work in case anyone in the future comes across this thread for answers.
Old Apr 12, 2011 | 12:25 AM
anthony1's Avatar
I don't know if you thought of regearing also. You are now geared lower than stock...but I guess you were already lower than stock with auto and 5.71 on 33's. I run 35's with R150F and 5.29 gear.
GreenLion
Jun 7, 2021 10:49 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
TheManOutside
Jun 18, 2015 03:32 PM
bobbybouche
Jun 18, 2015 10:22 AM
