Starter trigger wire
Old Mar 27, 2021 | 05:38 PM
Jrgunn5150's Avatar
I have an 88 4runner, factory auto 22RE. All of the EFI/ECM/trans control is gone along with the harness.
It is now a Mercedes OM617/R150 5 speed.
I'm trying to locate a starter trigger wire, there is no fender relay on auto's. Not sure what may have been missed with the neutral safety switch or TCM, I feel like the easiest way to do this is just pick up whatever the starter trigger wire is out of the column.
Does anyone have a pinout or diagram of the column?
Old Mar 27, 2021 | 08:21 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
I don't have those, sorry.
RAD4Runner has some extensive info in his threads about the goofy start circuit that sends starter solenoid current thru the key jobby.
Not 100% certain if it applies to 88's, but its a pretty good edumacation.
Did you make a build thread?
Old Mar 27, 2021 | 08:46 PM
coopster's Avatar
Hah. IRad's stuff is a sticky on this forum!
Old Mar 29, 2021 | 06:57 AM
Jrgunn5150's Avatar
Found what I need, it's black/white out of the switch, down to the trans module, then NSS, then a bunch of other crap.
I just picked it up at the switch to be done with it.
BIG RON
3.4 Swaps
Nov 15, 2023 06:17 PM
flashkl
Oct 20, 2012 04:56 PM
milowilli
Dec 30, 2010 06:18 AM
chrisms86
Sep 15, 2008 02:44 PM
